Old 10th April 2010, 11:46   #1
Thanked: 36 Times
Default Maruti Zen- Current divided between head light and left side indicator
Hey Guys
My ten year old Maruti Zen which has clocked around 1L Kms is down with a peculiar problem. Recently, my car's alternator was replaced. After a few days of problem free running, I observed that when I switch on the head lights, the left hand side head light is very dim and the left indicator (all of them) are also switched on but very faintly. But, when I don't switch on the head lights, that is, during the day the indicators work fine. The alternator functioning was checked after replacement by an authorised service center with an Engine scanner. What could be the problem guys?
Best regards
Abhinav Sharma
abhipuru16 is offline   Reply With Quote
Old 10th April 2010, 12:09   #2
planet_rocker's Avatar
Thanked: 365 Times
check the wiring of the LHS headlamp / LHS indicator. you can DIY as wel.
Keep us posted. all the best.
planet_rocker is offline   Reply With Quote
Old 10th April 2010, 13:37   #3
Thanked: 36 Times
Where is the wiring? I have no idea!
Old 10th April 2010, 16:24   #4
WhiteKnight's Avatar
Thanked: 73 Times
Take it easy- this has nothing to do with your alternator.
Simply put, your left headlight and indicators are now connected in a series, making each of those bulbs to share the voltage. Any competent electrician would be able to sort it out.
Else Try a DIY as planet rocker suggested.
WhiteKnight is offline   Reply With Quote
Old 10th April 2010, 16:41   #5
ilangop's Avatar
Thanked: 578 Times
Hi Abhi,
The ground wire would have got oxidised and the indicator is glowing due to grounding via HL. There could be some oxide on the bulholder that creats a high resistance path. A piece of sand paper could clear the problem. This use to happen often my dad's Premier Padmini. The ground connection use to be the problem.
For PP & 118 NE owners, you could see the fuel guage oscillating in tune with the right indicator lamp. This indicates that the ground connection is improper for the fuel float system / rear left indicator lamp.
ilangop is offline   Reply With Quote
Old 10th April 2010, 17:08   #6
Thanked: 36 Times
@Ilangop- spot on man! My horn had fallen off from it's place causing the head lights and the indicators to get incorrect grounding. It was a 5 minute job. Everything is fine now. Thanks a lot.
Current road conditions between Siliguri and Guwahati ? Saurabh M Route / Travel Queries 38 1st October 2017 21:46
Headlamp & Indicator Switch - Right or Left side of steering? clevermax The Indian Car Scene 87 9th March 2016 15:19
Interesting facts about Left Side or Right Side Driving kreddy Street Experiences 28 7th November 2013 14:30
Dent and Scratch on the rear - left side door bangboy Street Experiences 25 5th January 2007 12:38
Overtaking indicator - Right or Left prince1a Technical Stuff 5 7th October 2006 04:36
