Old 11th April 2010, 13:11   #1
greenhorn's Avatar
Thanked: 1,516 Times
Default Can I beef up my rear hatch door hydraulics?
After installing a pair of ovals on my indica hatch door, it doesnt stay up now ( I imagine its due to the weight)
Can I do something to beef up the hydraulics to cope with the added weight ?
Old 11th April 2010, 15:53   #2
mooza's Avatar
Thanked: 271 Times
Maybe another damper cylinder could be added, I suppose, by introducing an additional bracket? I do not know if there is place for this, though ! Some pics might help.
mooza is offline   Reply With Quote
Old 11th April 2010, 16:10   #3
Sankar's Avatar
Thanked: 4,639 Times
Measure the length and try to match with any other vehicle with a heavier hatch, for example Omni/Qualis etc. Some suv type vehicles do have gas struts for the front bonnet, you may check out those too.
If all fails you will need to figure out a way to add another damper or get a bonnet stay rod kinda thingy made up.
Old 11th April 2010, 19:17   #4
greenhorn's Avatar
I too was thinking about swapping it out with something heavier duty. the thing is a suspa liftline, but couldnt get any model numbers. just "indica" mentioned
Old 15th April 2010, 10:11   #5
Sankar's Avatar
Just measure the dimensions and go to a parts dealer. Or better still remove the one on the hatch and take it with you.
Try Swaraj at Killipalam first since they seem to cater to multiple brands.
Old 15th April 2010, 11:30   #6
dr.faramroze's Avatar
Thanked: 13 Times
The same happened to my mom's m-800 after fitting pioneer ovals and the hatch door was preety heavy. I have also seen some local mechanics in guj fitting the extra heavy duty hydraulic hatch ejector. I feel could later crop issues like loose fitment, rust or complete malfunction.
dr.faramroze is offline   Reply With Quote
Old 15th April 2010, 12:15   #7
n.devdath's Avatar
Thanked: 2,147 Times
You could try to use a Safari bonnet hydraulic pump which is designed for heavier loads. It should be available quite easily though I m not aware of the amount of modification it would require to fit.
Old 15th April 2010, 13:13   #8
ghpk's Avatar
Thanked: 193 Times
Are you guys fixing Speakers on Hatch Door itself ? if yes, a Pic would be help us other with more ideas.
Honda recalls 3,879 units of the City CVT - Updated software to optimize CVT hydraulics ashwin.terminat The Indian Car Scene 6 27th October 2015 16:57
5745.4kms, Door to Door, 4 States and 1 UT Judemayne Travelogues 30 23rd April 2011 21:56
Hydraulics in India? nakedflame Modifications & Accessories 45 12th August 2008 18:40
Reds Pro Series Hydraulics 4 Pumps LandSpeed Shifting gears 0 20th October 2006 01:19
