Old 11th April 2010, 21:59   #1
Thanked: 86 Times
Default Laura - New Turbocharger, but poor FE
Okay, so I blew the Turbo charger the other day, and ran up a handsome bill of Rs. 2.07Lakhs and got it replaced.
However, ever since I've got the new Turbocharger, the car seems to stall while getting off red-lights (low RPM move out) and the fuel consumption has gone seriously wonky from 17kmpl down to about 12.5-13kmpl.
Someone told me that I need to get the turbo re-mapped and configured, and since both Silvertone Motors and Continental are shutting down, I have little faith in the other Skoda service stations in Delhi.
Any suggestions would be more than welcome.
duke is offline   Reply With Quote
Old 11th April 2010, 22:26   #2
abhinav.gupta88's Avatar
Thanked: 310 Times
Try Fahrenheit or Arshia Motors. My experience with Fahrenheit has been good.
Old 11th April 2010, 22:42   #3
Thanked: 46 Times
I may not be able to help you out with your problem but am curious to know how did you manage to blow up your turbo charger???? And what is the odo reading of your car??
Cheers!!
sumitdongerkery is offline   Reply With Quote
Old 12th April 2010, 14:03   #4
nitrogary's Avatar
Thanked: 144 Times
no. you do not need to remap your turbo. unless it is a VTG. with feedback. we dont have these in india.
please check if the hoses are correctly connected back in their place.
if it is really a problem with the t/c, you will get lower mileage and very high smoke.
please revert back after checking.
nitrogary is offline   Reply With Quote
Old 13th April 2010, 10:08   #5
Thanked: 103,348 Times
Duke, sorry to hear about your Laura's turbo-charger failure. How many kms up on the car?
Whoever has replaced the turbo has obviously done a shabby job (most prolly with the plumbing). However, it is that same service center which should set things right. Why should you go somewhere else and pay more, after having footed the 2.xx lakh rupee bill. Where did you get your turbo replaced from?
Old 13th April 2010, 13:46   #6
anantnehru's Avatar
Sorry,OT - but Silvertone and Continental are shutting down?? When?
anantnehru is offline   Reply With Quote
Old 13th April 2010, 17:12   #7
Thanked: 86 Times
@abhinav.gupta88 - Will do... next stop Farenheit
@sumitdongerkery - Search me, Even I have no clue, I just accelerated a bit on the DND Toll bridge and *KAPUT* the turbo charger blew up (inside my pocket).
@GTO - The odo is south of 60k (by a bit) right now. The reason I'm going to another Skoda Service Center is because (1) Silvertone & (2) Continental are shutting down.
Skoda Laura Ambiente MT TDI. EDIT: A poor experience with Giriraj Motors Behemoth Test-Drives & Initial Ownership Reports 110 16th September 2017 17:10
Which is more effective Turbocharger or Supercharger ? Shan2nu Technical Stuff 120 25th February 2015 13:34
State of plastic fitments on cars : Poor quality or poor maintenance? libranof1987 Technical Stuff 10 15th January 2011 21:14
Turbocharger failure in new safari 2.2VTT(Edit: Solved; only a cracked rubber tubing) DDDHRUV Technical Stuff 104 11th May 2008 22:36
Supercharger or turbocharger? sridhar24 Technical Stuff 1 22nd September 2004 11:13
