Old 12th April 2010, 09:50   #1
Thanked: 3,835 Times
Default Noise while engaging clutch pedal in santro, AC cooling also less
Recently my santro has a couple of problems:
  • clutch pedal makes a "kitik" noise when pressed fully to change gears
  • I got the AC service done and gas topped up, yet cooling is pathetic and compressor cuts off frequently.
Any solutions to this?
sidindica is offline   Reply With Quote
Old 12th April 2010, 10:05   #2
aargee's Avatar
Thanked: 2,105 Times
Is this A/C for car or A/C at home? I'm asking this question out of ignorance because I'm under the impression that once the A/C compressor starts working in cars, it doesn't stops for cut off or to save power/fuel. But for the A/C at home, yes there's a cut off mechanism to save electricity. Could you explain this further?
Old 12th April 2010, 10:12   #3
AC for car ofcourse. It takes time for cool air to come out of the vents and I think that the compressor cuts off as I have to press the button of AC off and on to get cool air. The AC service was done at Hyundai workshop with all passages cleaned.
Old 12th April 2010, 10:23   #4
Thanked: 105 Times
Might sound a bit strange here but my VTEC has a similar problem and the mech says it's due to the clutch. Apparently I have also noticed the AC effectiveness going down suddenly when the car is in heavy traffic and I have to engage-disengage the clutch a number of times. The temp needle also goes beyond the half-way mark. The mech says the clutch needs an overhaul. He also made me feel the transmission tunnel (just to prove), which does become quite hot under such circumstances. Hope this helps.
avinash_m is offline   Reply With Quote
Old 12th April 2010, 10:27   #5
aargee's Avatar
Ok; but this is not to be confused with the compressor being cut off with a thermostat.
Sid, you don't need to worry if it takes less than 5-6 seconds in the late mornings. Just try checking this during early morning around 6-6:30 AM & the chilness should be felt immediately.
Do you need to switch OFF to get a cool air? OR do you need to switch ON & OFF the A/C button serveral times to get cool air? When you do this switching ON/OFF do you feel or hear the idling sound of engine & sound of compressor motor running increase (when switching ON) and decrease (when switching OFF)?
Palio 1.2 nv - Pressing the clutch pedal while starting the car kapilsharma80 Technical Stuff 24 18th February 2013 22:12
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
Clutch Slip when engaging 5th gear in Toyota Innova The Truth Technical Stuff 6 23rd September 2009 18:24
