Old 16th April 2010, 18:33   #16
planet_rocker's Avatar
Thanked: 365 Times
checked the hazard light switch? switch it on / off couple of times?
with ignition/engine & headlights (/& fog lights) on try this:
1. switch on indicators (LHS and/or RHS) and see any thing abnormal with the brake light / tail lamp / head lamp (with high beam) / side lights (parking light) - check for irregular lumen / blinks
2. repeat above (without starting engine) - slot in the reverse gear and check the working of the lights including reverse lights.
if everything is working perfectly - the problem lies somewhere else.
all the best.
planet_rocker is online now   Reply With Quote
Old 16th April 2010, 19:00   #17
extreme_torque's Avatar
Thanked: 1,317 Times
Originally Posted by Jaggu View Post
So you mean to say its the relay thats making sound? If so first thing is to completely check the turn light wiring, connectors, earthing points etc.
Originally Posted by ravikn View Post
I might be wrong here, but is this anything to do with the combination switch? just making a wild guess since that kat kat might also come if there is some internal loose connection in the switch.
@jaggu.. Yes its the relay in the flasher thats making sound. The mechanic has checked the earthing and cables but they are all fine.
@ravikn -- The mechanic did say about the combination switch but what I am not sure is why does the sound go away when I brake or turn the headlight on?
extreme_torque is offline   Reply With Quote
Old 17th April 2010, 12:06   #18
Dr.AD's Avatar
Thanked: 1,091 Times
In my 2002 Palio 1.2 ELX, I have a minor version of the same problem. Evey time I use the horn, there is this same "kat" sound from the relay. Since, this "kat" sound comes at the same time when the horn blows, the sound gets "hidden" and it is difficult to hear (hence the problem is not even noticeable). But when I pay close attention, I can hear this "kat" sound. This started happening around 4 years ago. I showed it to a mechanic who said this is a "relay sound" and is normal. It is there since last 4 years. Since there are no other problems associated with this in any sense, I am ignoring it and I haven't faced any issues so far.
By the way, in my car's case, the sound comes only when I use the horn and not when I use any other electrical equipment. But I believe the root cause must be the same in our cars.
Dr.AD is offline   Reply With Quote
Old 18th April 2010, 19:45   #19
jeeva's Avatar
Thanked: 527 Times
I hope you have a remote central locking system, and an after market one at that one. Is the power window control connected to the central locking unit? (when you lock the car, the windows roll up automatically)
It could be a faulty relay or a loose wire end or maybe even the actuators of the same.
Just my 2 cents.
jeeva is offline   Reply With Quote
Old 20th April 2010, 15:28   #20
Rehaan's Avatar
Thanked: 22,566 Times
...Yes its the relay in the flasher thats making sound. The mechanic has checked the earthing and cables but they are all fine...
As i mentioned on the last page. Replace it!
Originally Posted by Dr.AD View Post
....this "kat" sound comes at the same time when the horn blows....
Relays are basically a mechanical switch where a smaller current can switch a much larger current.
Inside the relay is an ELECTROmagnet that pulls a spring loaded contact towards it when activated. This is the click sound you hear.
If the sound really bothers you - you could change the relay with some sort of solid-state device (ie no moving/clicking parts).
cya
R
Old 20th April 2010, 15:44   #21
@rehan... I even changed the relay but that also started to kat kat withn in 5kms from the mechanic's shop! I will be visiting Samyak Motors tomorrow or day after and see what transpires.
Old 18th May 2010, 17:44   #22
Default Need mechanic contact who knows Palio electrical circuit
Even my palio(1.2 / 8 yrs old) has similar problem. I have a wiring with relay for my Hella rally lights but that is running fine for 1.5 years.
There used to be a sound when i switch on the A/C. These days, that sound comes even without switching on the A/C..while driving the car...while braking etc.
The major worry is, all the bulbs in my Palio (Car head lights / indicator / tail lamp etc) are going off one by one.. i have had 4 different incidents within a single month..some times, the bulb is just fine but the current does not go to that bulb. I learnt that Concord motors dont have people who knows about Palio electricals fully..they are just learning with my car.
If any of you guys know any good mechanic who knows well on the Palio electrical circuit, please give me the contact. I am going to change the headlight assmbly as well.
Daddy is offline   Reply With Quote
Old 19th May 2010, 12:02   #23
Thanked: 18 Times
@Daddy,
You can Contact Mr. Venkatesh from Gowri Automobiles, near SajjanRao Circle. He has a Palio electrical expert with him who is handling all electrical work Retro/PreNv/NV Palios from last 10+ years. I hope this place should address your problem. I have been visiting his workshop for more than 3 years now and am a happy customer since all the problems do get addressed without fail. You can refer my name when you call him.
Ventakesh's ph: 9379192193
Good luck n hope your electrical issue will get addressed soon.
ravikn is offline   Reply With Quote
Old 19th May 2010, 12:56   #24
thanks for the details Ravi. Will contact him soon.
Old 19th May 2010, 23:19   #25
Thanked: 65 Times
Exactly same with my Fiat Petra 2004. Kat Kat sound comes only when using horn.
rikhav is online now   Reply With Quote
Old 8th April 2011, 15:10   #26
Thanked: 110 Times
Default Re: 'Strange'st electrical problem in Fiat Palio 1.2
Sorry to dig up the old thread. I am having a peculiar issue with my GTX though its not disturbing but neverthless. when I turn the left and right indicator the dashboard indicator works. But when I turn the hazard light turn indicator on the dashboard is not working. When you slightly press on one side indicator is showing in the dashboard. Mechanic told to replace the whole hazard switch assembly . Today I had a chance to dismantly the center A/C assembly. I found that they broke the two screws holding the A/C console. Upon stripping the entire switch assembly I found they have sprayed too much oil. Cleaned everything with IPA followed by WD40. Hooked up the hazard switch in a multimeter and I found out its working perfectly.
I am trying to explain the scenerio in best possible way. The top three pins are power pins A,B,C. A and C carries + 12v. When Hazard switch is not used the power is supplied from A to B. When Hazard switch is used B gets power supply from C to B. On the bottom of the switch it has another 4 pins E,F,G,H. When the power is just connected and hazard lamp is not turned on pin F is getting 6.5V. When you press the switch the value cycles between 0 &12V (Flasher ) on four pins. When you Tape the pin E and use flasher Dashboard light blinks but left side indicator is not working. This makes me belive when you press on one side the switch is not making contact with pin E so momentarily the flash is showing in the dash when you press fully in all 4 pins engage and makes the dash flasher to go off. Does this mean some where in the wire they have taken 2 positive leads to the led flasher.
vijaycool is offline   Reply With Quote
Old 9th April 2011, 19:09   #27
Thanked: 9 Times
I also feel it is a faulty cutout which is making this kat kat noise, which area does this noise come from?
pratikraveesh is offline   Reply With Quote
Old 11th April 2011, 13:05   #28
Thanked: 110 Times
IMO, it's a short somewhere. I had the same problem with my 1.2 sometime back, got it fixed just in time before I could go insane.
mb_jg is offline   Reply With Quote
Old 20th May 2011, 18:10   #29
bejoy's Avatar
Thanked: 409 Times
@vijaycool, I am having the exact problem for ages.. May be from the second year onwards. I have ignored it and living with it. Did you manage to solve the problem?
bejoy is offline   Reply With Quote
Old 21st May 2011, 11:07   #30
Thanked: 110 Times
I have opened the Dash and found that autocop security wires has been taken from the hazard light wiring. when we open the doors the hazard light blinks thrice. I am guessing that could be the culprit.
Vijay
Strange Electrical Problem on P180 Fountainheader Motorbikes 17 13th March 2011 22:57
Strange problem with Palio 1.6 stile vidushak Technical Stuff 10 17th May 2009 23:18
strange problem in my palio D garychopper Technical Stuff 6 20th May 2008 13:18
Strange Palio Problem? 1.2 ELX extreme_torque Technical Stuff 7 2nd October 2007 23:05
