Old 15th April 2010, 21:04   #1
rrsteer's Avatar
Thanked: 937 Times
Default M800: Problem in slotting the car into gears
Hi All,
I have a 3 year old, 28K run, regularly serviced M800. Recently, and intermittently it becomes very difficult to engage the car into any gear. It takes a lot of force to put the push the gear stick and slot the car into any particular gear. Sometimes I have to use so much force that it feels as though the gear stick will bend.
What do you think the problem is and how can this be corrected?.
rrsteer is offline   Reply With Quote
Old 15th April 2010, 22:14   #2
greenhorn's Avatar
Thanked: 1,518 Times
do you have this issue all the time?
try it with the engine off, and also when the car is moving?
greenhorn is online now   Reply With Quote
Old 15th April 2010, 22:16   #3
Jaggu's Avatar
Thanked: 8,686 Times
Have you checked your clutch adjustment and inspected the cable? Also check if the gear lever bushes are intact
Old 15th April 2010, 22:26   #4
humyum's Avatar
Thanked: 2,502 Times
Also check the gear linkages. Sometimes a stone hit can bend the linkage and cause hard shifting.
Gear not slotting in Swift hyper-VTEC Technical Stuff 15 26th February 2017 13:02
Indigo DICOR 3rd and 5th gears popping into Neutral automatically. wanderernomad Technical Stuff 3 8th April 2011 22:27
Noise & Jerking the M800 while giving accelerator in 1st & 2nd gears. vinfriend Technical Stuff 1 22nd May 2009 23:45
What happened to M800 with 5 gears vincentt The Indian Car Scene 24 7th September 2006 18:46
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
