Old 17th June 2014, 14:04   #46
Default Re: The life of a 1.4 DuraTorq Engine from Ford
Originally Posted by interc00led View Post
Don't put any metal conditioner in the oil. Instead, try to use Iftex System D (fuel additive)to clean the injectors.
During that 4-5 sec lag, does the RPM increase ?
Points towards a severely chocked catalytic converter. If the catcon looks clogged even after cleaning then just break and remove it .
Thanks will get it done, sorry everyone for delayed response, slightly tied up at the office.
Oh on RPM, it is not the same torque-RPM correlation as in normal condition. Its as though I am having my leg softly on the clutch pedal and rev it up, after 2 sec it just opens up, like removing my leg from the pedal.
Looks like catcon let me first get it cleaned and give my feed back.
Shanks
myshanks is offline   Reply With Quote
Old 5th August 2014, 14:53   #47
ok I think I have no option but to get the engine opened. Now I have 2 options, either get the engine done up and assemble or pick up a sealed engine from a believable person either in Bangalore or anywhere.
If I have to get it opened, let me know some decent mechanic who would do a quick and good job in Bangalore.
Help and option to take is welcome
Shanks
Old 28th November 2014, 20:45   #48
adit mishra's Avatar
Originally Posted by govigov View Post
All,
What is the maximum number of kilometers that somebody was able to run this engine before an major overhaul? Somehow i think that cars that have theses engine cannot be driven for many kilometers like other engines in the market like the 1.3 MJD. Infact, i have never heard of a fiesta crossing 1,00,000 km mark. has somebody done this?
govigov
The Ford Fiesta Duratorqs run on an average 1,50,000 to 2,00,000 kms. A Duratorq becomes very expensive to maintain after 1,00,000 kms. There is a special Ford-specific garage here that looks like a shanty, but step inside and you will be amazed to see 2-3 Endeavours and 6-7 Fiestas. Some nostalgic owners still hold on to their Duratorqs after 100000 kms but they buy an alternate efficient car like the swift/Ritz/alto. The Fiesta Duratorq basically leads a retired life after 100000 kms.
On the other hand, the old swift Diesel DDIS can run 300000 kms on good Diesel without an engine rebuilt. Swift DDISs with 230000 kms on the odo can be seen in some areas of India. I had a chance of sitting in such a swift when I visited Sikkim. super silent and smooth. It has been our office car since 6 years. Perhaps the cooler climate and Assam Oil Diesel has worked wonders for the car. On the sub continent you will rarely come across such a DDIS.
adit mishra is offline   (1) Thanks Reply With Quote
Old 28th November 2014, 21:37   #49
Thanked: 716 Times
This "i have seen x,xx,xxx km'' on the odo of this ddis/tdci/dci, so this engine is the best" argument holds no value.
It all depends on the usage(urban/highways), limiting excess revving and making use of the torque, timely oil service, quality of fuel and such.
ramzsys is offline   (4) Thanks Reply With Quote
Old 8th February 2015, 22:16   #50
Thanked: 78 Times
Needed some advice, looking to buy a Second hand Ford fiesta 1.4 diesel,basic version.
23k kilometres,2010 registration, person is quoting 4.25 lacs, the exteriors are in excellent shape, taking it to the ford sc tomorrow to get it checked.
pls advise whether it is a good deal.
Shailesh
aspire is offline   Reply With Quote
Old 8th February 2015, 23:04   #51
sammyaulakh's Avatar
Thanked: 29 Times
Ford is known for its tough engines.i have a 2008 fiesta which is used by my mother just for local running.it has clocked 130000 till date without any major problems except for replacement of wear and tear parts.
One of my friend's drove his fiesta for nearly 300000 despite it being overheated twice due to faulty radiator bottle.
sammyaulakh is offline   Reply With Quote
Old 1st March 2015, 21:10   #52
glenmz's Avatar
Thanked: 276 Times
I have noticed a drop in engine oil levels for my Fiesta Classic 1.4 TDCi. It has dropped by about 40% on the dip stick. I checked the location where it has been parked, there are no oil drops there. Checked the exhaust for any oil residue, noting. The car has run 63000kms. Any suggestions? I plan to get the car checked tomorrow.
It has run about 5000kms since last service and that was about 6 months ago. Technically, the car is due for next service. The last 6 months of running has been covered mostly in the city.
glenmz is offline   Reply With Quote
Old 1st March 2015, 22:04   #53
Thanked: 14,604 Times
Check the coolant one too see if there is any mix of engine oil and coolant.
a4anurag is online now   Reply With Quote
Old 2nd March 2015, 12:29   #54
glenmz's Avatar
Thanked: 276 Times
Anurag, Thanks for your response. I checked the coolant reservoir, it did not have any oil traces.
Took the car to service, SA claims its alright and he did not find anything else wrong. So do the technicians. Let me see how she comes after service.
BTW - power steering hose was found leaking. So, some Vitamin M will go off now :(
Old 2nd March 2015, 12:36   #55
mayankk's Avatar
Thanked: 3,559 Times
An---------snip--------ow :(
Open the engine oil filler cap after a good run. See if there are any whiffs of white coming out.
mayankk is offline   Reply With Quote
Old 2nd March 2015, 12:43   #56
Thanked: 436 Times
May be a bit off topic here! But pardon me.
What is the fuel tank capacity of Ford Fusion 1.4 TDCi?
JoseVijay is offline   Reply With Quote
Old 2nd March 2015, 14:32   #57
glenmz's Avatar
Thanked: 276 Times
Takes 45 Liters of Diesel; approx.
Forgot to mention this. SA claims TDCi consumes about a litre of oil every 10000 kms.
glenmz is offline   (1) Thanks Reply With Quote
Old 3rd March 2015, 05:45   #58
Thanked: 436 Times
Thanks for the information. I thought it would take in only 37 liters. Or was it not 37 liters when the Fusion was introduced and then upgraded to 45 liters tank with the FIGO? Last time when I went to fill fuel, the tank was close to empty as the DTE was showing only 130 kms range and it took in only 31 liters of diesel.
Can please somebody clear my doubts? Thanks.
Old 3rd March 2015, 06:12   #59
govigov's Avatar
Thanked: 531 Times
Even with DTE close to zero, it would still run about 10-15 kms.
govigov is offline   Reply With Quote
Old 3rd March 2015, 22:36   #60
vnabhi's Avatar
Thanked: 1,317 Times
@Josevijay---it was always 45 liters for the Figo, Fiesta Classic and Fusion tdci. I'm not sure if the initial lot of petrol Fusions had a lower capacity, but that is hardly probable. The Fusion TDCi came much later, and at that point of time, the capacity was surely 45 liters.
vnabhi is offline   (1) Thanks Reply With Quote
Ford Fiesta 1.5L Duratorq Engine - Based on European 1.6L TDCi or the old 1.4 mill? ssenhyd Technical Stuff 43 4th March 2015 11:46
Duratorq-in' with Josh: Ford Ikon TDCi * 4 years 7 months/43,941 km & Letting Go :( condor Long-Term Ownership Reviews 441 16th September 2013 13:14
From Fusion to Fusion: My Ford Fusion Diesel Plus (TDCi/DuraTorq) Glass Test-Drives & Initial Ownership Reports 87 9th July 2013 19:50
Brush Steel Ford Ikon 1.4 TDCI Duratorq Review 18,000 km update Dieseled Long-Term Ownership Reviews 41 25th February 2010 14:13
Got My Ford Fiesta 1.4 TDCI 'Duratorq' Sxi Premium SriSri Test-Drives & Initial Ownership Reports 49 28th October 2009 16:29
