Old 19th April 2010, 11:05   #1
Jimmy_u's Avatar
Thanked: 78 Times
Default Esteem Diesel AC Compressor Needs Replacment
Hi Team,
I drive an Esteem Diesel (yes u read that right friends)
Its been my workhorse for quite some time now.Recently the AC compressor died on me . I need advice from the forum of a good AC mechanic in Bombay who can help me get a replacement .
The parts are hard to find since the casing/fittings for the Esteem petrol and Diesel are different, i have checked and verified this information,rest of the parts are same .
If someone knows a good mechanic who is reliable and know his stuff please advice me asap. The heat here in Bombay is killing as you all would know.
Thanks & Regards.
Jimmy_u is offline   Reply With Quote
Old 19th April 2010, 11:11   #2
nick17s's Avatar
Thanked: 93 Times
what is the exact issue you are suffering, as my compressor's bearing are making a lot of noise, and car's a/c is not cooling if car is stationery. (my mechanic told me compressor cant be repaired and even if you repair its temporary and waste of money) When I am driving a/c works fine.
nick17s is offline   Reply With Quote
Old 19th April 2010, 19:09   #3
Thanked: 103,701 Times
I go, and have been going for over a decade, to Four Seasons (Tardeo) for all my air-conditioning requirements. They are amongst the best when it comes to a/c's. Drop them a call & book an appointment. I'm sure they'd easily be able to fix your unit.
Old 20th April 2010, 11:08   #4
Jimmy_u's Avatar
Thanked: 78 Times
Hello GTO,
Thanks for the update.
This is the info i found online
4 Seasons Automobiles P L
24 Tardeo Rd , Jaywant Indl Estate ,
Tardeo , Mumbai: 400034
Tel. No.56633993
Please let me knwo if this info is correct .....
Old 23rd April 2010, 08:53   #5
Jimmy_u's Avatar
Thanked: 78 Times
It started on a Similar note and the car when stationary started to heat up.
In a couple of days driving with the noise sparks were observed when i switch on the ac , the pully which is connected the power steering belt for the ac was producing sparks ,got it checked and found that ac compressor was dead
Will be going to the place suggested by GTO and update you if they are able to solve the issue.
Old 29th April 2010, 16:33   #6
benzinblut's Avatar
Thanked: 598 Times
@jimmy_u: I too own an esteem diesel and had the exact same problem. I got my AC compressor changed at vashi. If you need any info on this then let me konw.
benzinblut is offline   Reply With Quote
Old 30th April 2010, 11:11   #7
Jimmy_u's Avatar
Thanked: 78 Times
Hi ,
It would be great if you could share the details of the place where you had the compressor replaced.
If you can also share the cost and time it took i would really appriciate it .
Thanks & Regards.
Old 30th April 2010, 12:38   #8
benzinblut's Avatar
Thanked: 598 Times
Hi ,
Thanks & Regards.
The esteel Di is mostly driven by my father and also maintained by him. He recommends not to go to this guy unless you are out of optioins.
AC compressor + gas charging + Labor: 15000.
Cooling coil: another 5000.
The AC compressor was replaced about a year ago. The job was done well and my father was satisfied with this guy. But, some months ago, when the evaoprator was to be changed, thats when he lost trust in this guy. The quality of work was not upto the mark and he tends to overcharge. Parts quality also cant be trusted. The evaporator that he had fit was faulty and my father faced a lot of problem till the problem was ultimately solved
Currently, all the AC system is working fine, but my dad has decided not to go to him in future.
This is where I got the job done:
Aircon
Behind Neel Sidhi Towers.
Sector 12, Vashi.
Mr. Sonu (27801019).
My suggestion: Parts availability is a problem for Esteem Di. I suggest that you go to Shetty Motors and get the parts and get it fit at some reputed mechanic. Four Seasons at Tardeo is good.
Old 30th April 2010, 12:53   #9
Jimmy_u's Avatar
Thanked: 78 Times
Hi benzinblut,
Old 1st May 2010, 12:54   #10
I think The Compressor is Same in Esteem D and Zen D, A new compressor from Subros will cost around 10 K
avis_gan is offline   Reply With Quote
Old 4th May 2010, 13:06   #11
Jimmy_u's Avatar
Thanked: 78 Times
Hi avis_gan,
You are correct my friend.
They are the same.
I am contemplating to exchange this car as the exchange and repair are costing me the same price of 20000/- .
Old 4th May 2010, 13:32   #12
benzinblut's Avatar
Thanked: 598 Times
Hi avis_gan,
They are the same.
Yes Esteel Di and Zen Di had the same engine and the AC parts are the same as well. Infact its easy to procure if you ask for ZenD parts rather than EsteemD parts. I think there were more ZenD sold than EsteemD.
What does that mean? You will be getting a difference of 20K on a new buy against this esteemD? what year and model is your car?
Old 4th May 2010, 14:36   #13
Jimmy_u's Avatar
Thanked: 78 Times
Dear benzinblut,1868618]
I have asked for zen and esteem di parts but its like finding a needle in a haystack.
i am exchanging my old Esteem Diesel with this car and the difference quoted is Rs 22500/-
Specifications of the car !!!
Opel corsa 1.6 GLS
37000 KMs run
single owner
Dec 2003
Please let me know your feedback , if this car is a good buy !!!
Old 4th May 2010, 15:55   #14
benzinblut's Avatar
Thanked: 598 Times
Opel corsa 1.6 GLS
37000 KMs run
single owner
Dec 2003
Did you enquiry at MarutiASS? Theres also a shop 'Shetty Motors' in bombay (near keneddy bridge/opera house) and in new bombay. They could have this AC compressor.
Before doing any comparison, i need the following info:
Whats the year and month of your Esteem?
Is it Esteem D or Di?
What FE do you get in the Esteem?
how many km has it done?
Apart from ac compressor, are any other non standard parts (not sharing parts from petrol esteem) that are due for replacement?
I suggest that you read on ownership reviews of the opel corsa. I think that older cars are high on maintenance costs and parts availability is a problem.
Old 5th May 2010, 06:30   #15
Jimmy_u's Avatar
Thanked: 78 Times
Dear benzinblut;
following info:
may 2003
Di
15 appox
1.2 lacs
The cars cooling system
shocks
nothing else i can think of now
I suggest that you read on ownership reviews of the opel corsa. I think that older cars are high on maintenance costs and parts availability is a problem.[/quote]
I agree, maintenance i can live with as the parts for diesel esteem are also expensive when found , also my running was around 2000 kms a month which has now reduced to 1000 kms .
Let me know ur thoughs !!
Esteem's AC needs repair... udit78 Technical Stuff 27 18th March 2011 00:48
Replacment for Pirelli Citynet 175/80R14 gemithomas Tyre & Alloy wheel Section 13 5th March 2010 15:48
Esteem A/c compressor oil & gas issue (Poona) Raccoon Technical Stuff 5 27th September 2009 12:59
Power Steering and Compressor : Esteem Shashank.A Technical Stuff 0 15th December 2008 09:27
Kindly Advise - Esteem Done 80k Needs Suspension + Cluth Plate passion4cars Modifications & Accessories 4 8th December 2006 02:13
