Old 20th April 2010, 15:03   #1
Default Issues with my Baleno's electricals
Guys,
After a trouble free 5 years, i am encountering sporadic niggling issues with the electricals. The latest issue is with the fan and AC which seems to have a mind of their own, they function sometime and other times they dont. The green indicator lamp will be on but no air from the fan/AC.
I checked for
1) All loose connections
2) All the fuses and relays
Physically they appear to be allright i.e. connections in tact, no signs of a fuse blowout etc.
Any other place that i need to be looking to rectify this, appreciate any expert help
kiranpashtakar is offline   Reply With Quote
Old 3rd May 2010, 15:24   #2
Default Sos
Can anyone on the forum please help me, the condition is now detoriated, I am having issues with the Horn as well
Old 3rd May 2010, 15:33   #3
planet_rocker's Avatar
Thanked: 368 Times
i guess there is a loose connection from the AC / Fan switch to the AC / Cabin fan motor.
get the car checked at MASS. take a look at each fuse again. do you have rats where you park your car?
planet_rocker is offline   Reply With Quote
Old 3rd May 2010, 15:34   #4
Surprise's Avatar
Thanked: 272 Times
Did you took your car to the authorized service station or any other garage? If no, let the experts to work on it as any issues midway will put you in a spot of bother
Surprise is offline   Reply With Quote
Old 4th May 2010, 16:05   #5
Same problem was in my friends Wagon R. A/C fan was working for some time but got off later after running for 15-20 mins, Mechanic checked it and found to be Issue with some round black colored Relay. Bought new one of 'Interface' make and after change it is working fine for last 3-4 days.
Sang is offline   Reply With Quote
Old 4th May 2010, 19:25   #6
Jaggu's Avatar
Thanked: 8,686 Times
Check all the connectors/switch/relays/fuse etc. If all is fine, check the gas level, low gas levels might cut off the AC.
Old 5th May 2010, 01:26   #7
monster2's Avatar
Hi Kiran i hope u received my PM, Tht guy wud certainely help its a very small issue, and if the horn also goes there is earth wire behind the show grill where the horn is fixed which even connects to AC, get tht checked.
monster2 is offline   Reply With Quote
Electricals overhaul wanderlustindia Technical Stuff 1 7th July 2008 18:45
problem with car electricals harry2223 Technical Stuff 15 16th January 2008 18:05
New Electricals in Karizma Godma Motorbikes 13 25th December 2007 23:10
Any electrician in Pune who looks at vehicle electricals? spadival Modifications & Accessories 6 9th September 2007 12:28
Upgrading electricals COUGAR Modifications & Accessories 4 4th February 2007 21:30
