Old 20th April 2010, 17:55   #1
Thumbs up Rusting in Hydraulic wheel cylinder(Brake)
In older cars the hydraulic cylinders become rusted and the metallic piston which activates the rubber cups gets jammed after being idle for a couple of months. Ordinary grease cannot be used as it reacts with brake fluid. A specially formulated grease is supplied by Girling - TVS. It is not manufactured now but old stocks are available. It took me some time to identify this item. I have some pictures of the tube I found in Mumbai.
I thought this information may be useful to amateur restorers like me.
Ramanna
Ramanna is offline   Reply With Quote
Car with four cylinder engine or three cylinder engine? sunil8089 Technical Stuff 37 7th January 2018 21:06
Pros & cons of hydraulic clutch sbasak Technical Stuff 38 24th November 2017 20:12
Nissan to Recall Micra and Sunny Sedan in India, to Replace Brake Master Cylinder volkman10 The Indian Car Scene 44 18th July 2013 18:26
Rusting in Alto wheel cap AltoLXI Technical Stuff 13 31st August 2009 12:31
