Old 31st March 2012, 14:09   #16
Thanked: 7 Times
Default Re: Suspension issue on Fiesta 2007
No need for changing the coil springs. Check the ball joints. Also, the lower arm bushes.
Also, I guess at 78k your tyres should are about ~30k kms old? If so, they would also affect ride.
Thanks dhanushs,
Service guy says that lower arm bushes does not come separately....It comes as part of lower arm assembly. Lower arm is still in good condition.
Will check on the ball joints. Thanks.
Current tyres(XM1+) are running from 56k. So lot more life left in them.
denomathew is offline   Reply With Quote
Old 31st March 2012, 16:05   #17
dhanushs's Avatar
Thanked: 4,504 Times
Hi Deno,
Its usually the bushes that get damaged, and not the lower arm. And, yes, for Ford, you get only the whole lower arm, and not just the bushes.
However, if the bushes are damaged, it worth changing, for a better driving experience. After all, its no good driving a Ford with bad suspension, eh?
Old 31st March 2012, 16:06   #18
mitrajdeep's Avatar
Thanked: 92 Times
Hi denomatthew,
Is the price of the rear shock absorbers that you mentioned (2622) per piece or for two ?
mitrajdeep is offline   Reply With Quote
Old 31st March 2012, 16:58   #19
vnabhi's Avatar
Thanked: 1,317 Times
Hi Deno,
+1 to this viewpoint.
Normally lower arms and bushes need to be changed in most cars around 50 to 75 K on the odo, given the state of our roads.
I recently got my WagonR's lower arms and bushes changed with the odo reading 60 K. I had also got the front struts changed at 55 K. The car runs like new now.
Old 3rd March 2013, 22:58   #20
Optimus7's Avatar
Thanked: 12 Times
I have a suspension issue in my Fiesta 2007 TDCi. There is a thud sound everytime I go over a bad road. Over smooth bumps it breezes, but over rough patches there is thud sound. Also there is a squeaking sound from underneath the car for the past couple of months. Took it to F.A.S.S, they checked and told me that the suspension in weak and it needs an overhaul (odo reading 68K, bought the car with odo reading 55K). They quoted me 20K for 4 wheels (12K and 8K for the front and rear pair respectively). Is this the correct price?
I have no idea if the previous owner had done an overhaul. My only concern is, should I do it now and will the ride improve after this. The dealer promises ride like a new car.
Optimus7 is offline   Reply With Quote
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
MRF-MAI Indian National Karting Championship 2007: UD: 2007 Champions declared! Rtech Indian Motorsport 61 11th December 2007 15:58
PICS: 2006 Movistar, 2007 FZ6, 2007 Hornet 600 BunnyPunia Superbikes & Imports 39 13th August 2007 20:51
tata safari suspension issue? idrive Technical Stuff 11 6th October 2005 01:34
