Thread Tools
Old 14th October 2005, 17:07   #1 (permalink)
Default Corsa left side noise ...
Hi All,
Some ratling noise was comming from the left side of the bonnet, went to service center, the service center guys after inspection told me that both the front shocks are gone and need to be changed and one of the engine mount is broken, the car has done 21K only but is 2.5 yrs old, so no warrenty , done the changes but still hearing the noise but occasionally, gone back to the service center, after inspection they say every thing is fine, can some one please let me know what might be wrong, I never expected CORSA to have this type of problem, any help regarding this would be appricated.
pramods is offline   Reply With Quote
Old 14th October 2005, 17:16   #2 (permalink)
Team-BHP Moderator
Rtech's Avatar
Did they change the tie rods? if not, that is probably the source of the sound.
You my also want to check if the mudflap is loose. It happens at times and create a sound when you go over bumps.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 14th October 2005, 17:33   #3 (permalink)
gkrishn's Avatar
I used to get these noice once when i bumped out of a pot hole. They zeroed it on the dangling silencer. But still the problem existed, i was geting some noice when i was taking sharp u turns. Problem was with the slightly bent engine gaurd. Now its all silence out there.
Dont think that the shocks will give up at 21k itself. These guys are bloody lazy to locate the problem, i had to sit on their heads to get things done.
offtopic: how much did that process of changing the shocks cost you?
gkrishn is online now   Reply With Quote
Old 16th October 2005, 13:16   #4 (permalink)
It costed me 6k total including labor and wheel alingment, I think of taking the car to a local garage specialized in opel astra & corsa
Old 16th October 2005, 15:57   #5 (permalink)
Both front shocks + engine mount only12k??? pretty cheap i feel...This is including the cost of the parts???
__________________
Catch me if you Can
Catamaran is offline   Reply With Quote
Old 16th October 2005, 15:58   #6 (permalink)
Correction?!!! 6k i suppose and not 12k
__________________
Catch me if you Can
Old 17th October 2005, 09:38   #7 (permalink)
Yes, as paid and mentioned in the receipt, the costliest part is labor.
Thread Tools
Real use of Left Side Rear View Mirror !! mithun Technical Stuff 106 7th March 2008 16:28
Dent and Scratch on the rear - left side door bangboy Street Experiences 25 5th January 2007 11:38
Why is Petrol Tank inlets on the Left Side ? navdeep The Indian Car Scene!! 17 8th November 2006 09:26
Opel Corsa 1.4 GSi/ Corsa Sail 1.4 dsrins Hatchbacks 2 8th August 2006 17:47
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
