Old 3rd May 2010, 14:59   #1
smashnerd's Avatar
Thanked: 19 Times
Question Fueling Meter?
Is there any digital measuring equipment which one can put in the car to measure the exact amount of fuel delivered at the pump? Also, at what temperature is the fuel stored/delivered?
smashnerd is offline   Reply With Quote
Old 3rd May 2010, 17:39   #2
ghpk's Avatar
Thanked: 192 Times
never heard of this. however you can ask any petrol pump manager to measure the quantity of 1 to 5 litre of petrol in a industry approved measurement containers.
All petrol pumps also need to keep a density checking equipment as recommended by most Oil companies and government.
Old 3rd May 2010, 18:54   #3
smashnerd's Avatar
Thanked: 19 Times
OK, since it's not possible to fit any such device, are there any cars sold in India that measure the fuel in their tanks instead of just showing a full-half-empty gauge?
Old 3rd May 2010, 20:11   #4
Thanked: 89 Times
not sure about that. some do show how many more kilometers you can cover with the fuel available in the tank(known as range).
punto is one
sukrit7 is offline   Reply With Quote
Old 3rd May 2010, 20:17   #5
smashnerd's Avatar
Thanked: 19 Times
It'd be nice if such a digital gauge was made for Indian cars to help combat fuel pump cheating. If not one showing the true amount, then one that is fairly accurate and updates fast.
Old 4th May 2010, 00:14   #6
AbhiJ's Avatar
Thanked: 462 Times
I think the Logan has such a feature..
AbhiJ is offline   Reply With Quote
Old 4th May 2010, 05:08   #7
smashnerd's Avatar
Thanked: 19 Times
What?! Saving grace for the Logan??
Old 4th May 2010, 08:34   #8
joecherian's Avatar
Thanked: 78 Times
I think you can but some "flowmeters" that are available in market. I had asked the same question to my bro and he only pointed me to these flow meters and as per him, making one such meter is very simple it seems
joecherian is offline   Reply With Quote
Old 4th May 2010, 22:12   #9
Rehaan's Avatar
Thanked: 22,582 Times
Originally Posted by smashnerd View Post
....are there any cars sold in India that measure the fuel in their tanks instead of just showing a full-half-empty gauge?
Logan - http://www.team-bhp.com/forum/techni...-variants.html (Getting Numeric Reading of Fuel Remaining in Litres in Logan lower variants)
Not quite -- its a hidden feature
The thing is that most modern cars (esp. if they have a DTE display) know roughly how much fuel is in the tank.
However, they probably dont show this as it isn't as accurate as the petrol pump's guages - and they probably don't want a situation where you fill 40 liters at the pump and the car's guage only shows a change of 38 Lts.
cya
R
Old 4th May 2010, 22:49   #10
Thanked: 2,071 Times
Some of the latest dispensers show the density. Whether it is just a figure entered, or measured online, I don't know.
Flowmeters are available. Kent was a common brand. The nutating disc ones wern't very expensive (for people who bought fuel by the tankerload!).
Why the fixation with digital?
Sutripta
Old 4th May 2010, 23:27   #11
Rehaan's Avatar
...Why the fixation with digital?
I think he's used that term losely to mean "with actual numbers" rather than a needle on a vague dial.
Regarding your topic of fuel density, and how its measured, see these two threads :
Pumps with fuel density display
What should the fuel density be for different fuels? (Fuel Density - what should it be for different fuels)
FYI - fuel volume is only corrected for density (due to varying temperature) when the bunk buys fuel by the tanker, and NOT when the customer fills up their car.
cya
R
Old 5th May 2010, 05:45   #12
smashnerd's Avatar
Thanked: 19 Times
Thanks Rehaan. I meant meters showing actual numerical readings.
I hope such devices come standard on newer cars so we can atleast defeat the short-fueling tricks at the pumps.
Short Fueling Tricks At Petrol Stations ms_rana Street Experiences 588 8th October 2017 11:38
Does downstream O2 sensor affect fueling and FE in Petrol Engines? Sankar Technical Stuff 34 7th April 2016 06:57
Fed up of Cheating / Short fueling by Petrol Pumps? Look here dadu Street Experiences 57 11th February 2014 16:46
Wanted RPM Meter ! khaadu75 Shifting gears 7 15th August 2004 11:30
