Old 3rd May 2010, 17:08   #1
Otomobil's Avatar
Thanked: 24 Times
Question Towing ?
Hi Bhpian's !
Can somebody throw some light on this ?
Is it possible to tow the car,when the car is slotted to reverse gear and hand brake is on, while parking ?
My mind goes bonkers especially with this question offlate !
Cheers !
Otomobil.
PS: Guys dont be ready to jump with your guns.
Otomobil is offline   Reply With Quote
Old 3rd May 2010, 17:18   #2
Thanked: 245 Times
If you are wondering about, how did my car got towed like this.
The towing guys are masters in both,
- moving the gear lever from below the engine to neutral, whereever physically possible.
- Loosening the handbrake cable for rear wheels.
Old 3rd May 2010, 17:18   #3
planet_rocker's Avatar
Thanked: 368 Times
Yes it can be towed with the front lifted - the hand brake mechanism will be shot.
Did you come across a similar situation?
planet_rocker is online now   Reply With Quote
Old 3rd May 2010, 17:29   #4
Otomobil's Avatar
Thanked: 24 Times
Thanks Dadu ! : Never knew this. I mean can you shift the gear to neutral from the car from the bottom.
planter_rocker: not yet, I was told my colleague that this would prevent towing !
Old 3rd May 2010, 18:02   #5
UniqueMods's Avatar
Thanked: 50 Times
i didn't know that was possible. Do they tighten the hand-break cable later?
in mumbai these towing guys come ready with steel rulers, slide them into the window rubber lining, unlock the car in 2-3 sec flat, disengage the hand break, lift and off they go, all within a period of 30 sec.
having the car in reverse gear is useless in a front wheel drive car as the front is raised up.
i have personally seen them tow a car with the hand-break still pulled as they could not get it. the wheels screeched for 10-20 meters and then gave way.
UM
UniqueMods is offline   Reply With Quote
Old 3rd May 2010, 18:45   #6
james's Avatar
Thanked: 544 Times
They usually lift the front and mess up the front bumper. In most cases the handbrake cable is not loosened but CUT!
So at the end of it you end up paying the fine+ replacement/repair of bumper+ other small damages + hand brake cable + labout charges for the work.
Keep an eye out for those No-Parking signs!
james is offline   Reply With Quote
Old 4th May 2010, 22:21   #7
Rehaan's Avatar
Thanked: 25,043 Times
Otomobil,
I believe your logic is :
Handbrake is on -- therefore rear wheels are "locked"
Gear is engaged -- therefore front wheels are "locked" (assuming FWD car)
The above will make towing a car very difficult, however, as dadu and uniquemods said the towing guys have ways around this.
From what i've seen, its always the method of opening the door and then manually disengaging the gear + handbrake.
cya
R
Traffic Police menace - Towing away of vehicles. What are the legal recourses? Raccoon Street Experiences 41 25th November 2017 11:30
Mumbai Towing Service: Is this how our cars are towed? frankmehta The Indian Car Scene 133 8th March 2017 18:22
24x7 towing service - Ashish Towing (Mumbai) GTO Mumbai 6 10th August 2011 02:54
Impact of towing a car Haque Technical Stuff 50 25th May 2010 16:18
Fight against Towing Scuderia The Indian Car Scene 13 9th June 2008 21:59
