Old 7th May 2010, 13:30   #1
Shan2nu's Avatar
Thanked: 89 Times
Default Innovative Header Design!!
Found this on youtube. I wonder how effective they are, compared to traditional ones coz i see some layouts with sharp angles.
Shan2nu
Old 7th May 2010, 13:55   #2
pranavt's Avatar
Thanked: 274 Times
Better known as equal length headers. Usually better than unequal length headers.
Headers : Bisimoto Engineering, Where Efficiency Meets Technological Perfection!
Perrin Performance - Header Equal Length
Honda/Acura : Bisimoto Engineering, Where Efficiency Meets Technological Perfection!
Old 7th May 2010, 14:00   #3
Shan2nu's Avatar
Thanked: 89 Times
No, im talking about the way they are making it. Coz i haven't seen those kind of mock up headers being used here.
But coming back to equal vs unequal. I remember seeing a design where one pipe was shorter than the other, but they had different pipe diameters. Not sure where i saw it. Does any ducati bike use this?
Shan2nu
Old 8th May 2010, 16:19   #4
jalsa777's Avatar
Thanked: 1,065 Times
its pretty neat.
This is a very common problem faced by custom car builders. The usual practice is the take the chassis, engine and other basic components to the exhaust manufacturer.
The exhaust is made there, and then the other components are fitted around it.
This is a pretty good solution.
But, if you make our car on CAD first, then the exhaust can be incorporated there itself without the expense of such solutions
jalsa777 is offline   Reply With Quote
Old 8th May 2010, 16:34   #5
im_srini's Avatar
Thanked: 397 Times
Smile
A new way to bend pipes ?
im_srini is offline   Reply With Quote
Heads Up - Do NOT Use Header Wraps! 1self Technical Stuff 13 21st November 2009 19:33
Random Car Pics on Team-BHP Forum Header. EDIT: New Images Added! jassi Shifting gears 45 9th October 2009 22:00
header for zen in Bangy... Endofdayz Modifications & Accessories 22 28th November 2007 15:17
header help paras211 Technical Stuff 8 13th February 2007 21:35
Baleno Header & Exhaust & some Revvhead Technical Stuff 18 24th March 2006 10:24
