Old 7th May 2010, 22:37   #1
jalsa777's Avatar
Thanked: 1,065 Times
Default Ritz ZXi giving low mileage
my Ritz has done 2500 kms.
Ont he first tank-full, it returned a mileage of 10.9 kmpl.
I thought it was OK and would increase after first service.
Then, it went from bad to worse.
10.5 kmpl, then 10.1 and now, just 9.6 kmpl.
The car experiences only intra-city running. With air-con ON all the time
My driving style is such that i get around 0.4-0.5 kmpl less than an average driver.
But this is unacceptable low.
What can be the reason and what can i do about it?
jalsa777 is offline   Reply With Quote
Old 7th May 2010, 23:02   #2
DRIV3R's Avatar
Thanked: 1,433 Times
Check tire pressure. It should be 33 psi.
Check idle rpm. Should be around ~900 rpm.
If ok, check for CO% and get the vehicle tuned to the optimum at M.A.S.S.
If ok, check your driving style!
Change gears at ideal rpm, accelerate and decelerate steadily.
Check quality and quantity of fuel used.
BTW how did you arrive at this FE ? (Calculation part)
DRIV3R is offline   Reply With Quote
Old 7th May 2010, 23:04   #3
Eddy's Avatar
Thanked: 5,067 Times
Are you filling up from a reliable pump and measuring on tankfull-empty method ?
Eddy is online now   Reply With Quote
Old 7th May 2010, 23:04   #4
HammerHead's Avatar
Thanked: 211 Times
If I were you, I would have asked my friend, preferably light footed , to drive it one day on the same route that you normally take and see the difference. At least you will narrow down to if its you or the car!!! If its the car the try out fueling it from a different bunk.
HammerHead is offline   Reply With Quote
Old 7th May 2010, 23:53   #5
jalsa777's Avatar
1. The petrol pump i visit, its the same one from where all my other cars are being refulled since almost 15 years now. So, no problem there.
2. It had been driven by someone else who is light footed, same FE.
3. I did tank-full to tank-full runs. Filled, 36-39 litres on an average. The car ran for 350-400 kms.
4. Idle RPM is ideal, 750-900 rpm
5. The tires are filled with nitrogen to 30 psi. There are yokohama a-drives of stock size (i.e. 185/70 R14)
Old 8th May 2010, 00:03   #6
Nikhilb2008's Avatar
Thanked: 6,591 Times
How do you measure the pressure? I suggest you buy a gauge yourself for more accuracy.
Old 8th May 2010, 00:03   #7
DRIV3R's Avatar
I suppose that the recommended tire pressure is 33 psi. Report poor FE in the next service and see if it improves from then on!
Old 8th May 2010, 00:25   #8
Thanked: 16 Times
Recommended tyre pressure is 29 psi. 30 should be fine as well.
My Ritz ZXI is more or less giving the same mileage. Maybe a KM more than yours. Then again I am still at ~1800 Kms.
I hope you don't spend longs hours waiting in traffic jams. Jams would also affect the fuel efficiency.
anupamsinha is offline   Reply With Quote
Old 8th May 2010, 00:39   #9
DRIV3R's Avatar
Yup. 33psi is for the LXi/VXi. And 29psi is the recommended pressure for the ZXi. Same applies for the Swift as well.
Old 8th May 2010, 06:48   #10
vigsom's Avatar
Thanked: 603 Times
  1. Have you accounted for the numerous traffic hold ups in Mumbai?
  2. My suggestion to you is to fill up full Tank,drive the car with ac on an early morning on a route in Mumbai(i'd day EE Highway) for say 3 hrs at 60kmph,then again tank up and see how much you filled.
  3. distance covered/how much you filled second time=mileage.If this is in the region of 15-17 you're fine
The mileage drop(<10kmpl) could also be due to the horrid climate causing teh compressor to be on more than normal.
Old 8th May 2010, 16:08   #11
jalsa777's Avatar
my daily commute is from dadar to ghatkopar, that too in the opposite direction of the rush.
What are other ritz owners getting in mumbai?
Old 10th May 2010, 16:36   #12
siddharthp's Avatar
Thanked: 18 Times
Hi Jalsa777,
I am driving Ritz Vxi since one month,Covered approx 400 Kms.in Pune.
All city driving with AC switched on all the time.Average on tak full and tank empty basis is 11.03 ,which is pretty bad as I feel.I am driving at speeds not more than 80 kms as car is till very new.
I hope that it will improve after 1st service,but reading your post,I am worried now.Can somebody help?
siddharthp is offline   Reply With Quote
Old 11th May 2010, 10:00   #13
anky's Avatar
Thanked: 107 Times
Red face 11.5 Alto
Hi I get 11.5 w70% Ac on in mumbai traffic only 2nd & 3rd gear no other probs with car. chinchpokili to dadar in traffic everyday.
anky is offline   Reply With Quote
Old 11th May 2010, 10:11   #14
Thanked: 85 Times
Just ask them to check the tappet setting. This is a common problem. Quality control is not very good. A fellow BHPian had the same problem with an Alto and MASS couldn't figure it out. Finally he got it checked it elswhere and the tappets were wrongly set. 2 over tight and 1 loose. After setting it properly the problem was resolved. MASS of course claimed that the car was normal and the low milege was also normal. Try getting this done by a reliable workshop rather than at a MASS.
Live To Jive is offline   Reply With Quote
Old 11th May 2010, 10:23   #15
thelightening's Avatar
Tuning is possibe on engines with MPFI technology? on old days heard of tuning on engines with Carbs.
thelightening is offline   Reply With Quote
The "Low Mileage" Car Thread! How low is your running? saket77 The Indian Car Scene 135 23rd September 2013 22:51
My very own first car - Ritz Zxi or i10 Asta? EDIT: Booked Ritz Zxi. Gandhi Hatchbacks 93 24th November 2009 15:50
HELP - Palio giving low FE and poor performance (1.6) lamborghini Technical Stuff 0 17th June 2006 18:03
giving the Swift some low end torque and fatter wheels theEnd Modifications & Accessories 14 21st November 2005 19:07
