Old 25th November 2014, 20:24   #31
dark.knight's Avatar
Thanked: 3,388 Times
Default Re: Issues with a new Hyundai Verna
Originally Posted by noblecr View Post
Could you please see my 1st post.
Well lets try and see this logically. EPS is where a motor assists the steering so that your effort of turning is minimal. The motor draws current from the battery for its own functioning. The most probable reason you got the Check EPS light may be due to some problem in the wiring loop/motor which may have hindered flow of power towards the motor. This may have been set right after re-start of the car. I'm saying this because the EPS stopped completely until restart & didn't function intermittently like some cases.
The level of variable assist in an EPS is also programmed in the car's CANbus based on speed. So its better to get the computer scanned for error codes which may give more clues on the issue and/or reset it. As usual only the service station can give the best answer after an inspection.
dark.knight is offline   (1) Thanks Reply With Quote
Old 25th November 2014, 20:51   #32
audioholic's Avatar
Thanked: 6,147 Times
Since the warning light was On, there's a high chance of an error code that is stored in the EPS controller. Hence a scan will let you know if what the issue was. It can be some minor issue like a low voltage, or some sensor not providing legible data and so on and hence the EPS would have shut down. After you restarted the car things would have been reset. Suppose this repeats do observe what changes happen to the car, if any.
audioholic is offline   (1) Thanks Reply With Quote
Old 25th November 2014, 21:30   #33
yajaman99's Avatar
Thanked: 141 Times
The owner of the Verna did continue to use it for sometime and then sold it. He is now enjoying his Fluidic Verna.
yajaman99 is offline   (1) Thanks Reply With Quote
Old 9th December 2014, 17:01   #34
noblecr's Avatar
Thanked: 113 Times
Today only I got a chance to scan the ECU at the nearby Hyundai service center as the scanning device was not available. After scanning the guy told torque sensor malfunction was the recorded error. They have removed the error log and turned the steering wheel to both ends 2-3 times while the scanner is connected. They said that everything is fine now and if this issue happens again then we need to replace the torque sensor.
noblecr is offline   Reply With Quote
Hyundai Verna VGT: 50000 kms in 5 years. Pleasant experience at Trident Hyundai SantoshPV Long-Term Ownership Reviews 1 25th June 2013 14:50
My new car - The New Fluidic Hyundai Verna 1.6 SX(O) CRDI MT gandavadi Test-Drives & Initial Ownership Reports 28 24th July 2012 15:06
New Verna Sooner than you Expect: Launched as Verna Transform drchernish The Indian Car Scene 181 22nd July 2010 09:34
New "Executive Kit" for Verna by Hyundai + Other New Genuine Accessories VSG12777 Modifications & Accessories 76 3rd July 2010 21:03
Hyundai Verna Stolen with the Original Key Stolen from Hyundai Service Station .anshuman Indian Car Dealerships 56 3rd October 2007 23:46
