Old 11th May 2010, 11:54   #1
ajay2233's Avatar
Post Zen Ac Problem
Hi All,
I have a 1996 Zen Carb,in Chennai. I am having problem with my cars AC.
My mechanic has changed all kinds of hoses, and filled AC Gas. Now he says the Compressor is weak and needs to be changed.
I have already spent close to 5k on the system till now and there is no progress to it.
Please let me know how to find if the Compressor is in good condition.
Also will I get new 80cc compressor? How much for it?
@Moderators,
I did search for other threads , couldn't find one. If there is any other thread dealing with the same topic , ple post it there.
-Ajay
ajay2233 is offline   Reply With Quote
Old 11th May 2010, 23:09   #2
Thanked: 54 Times
If you are from chennai , just go the new college road . Before new college and as soon as after the new college gate you will find 2 car A/C parts shops . You will be able to find a new compressor . They stock most brands that are sold in India .
I think the name of the road is peters road .
Old 12th May 2010, 10:36   #3
dar3dev|l's Avatar
Thanked: 88 Times
well i had the same problem with my 97 crab zen ! Zen is known for its weak AC. While i am in pune, one of the MASS (Sanjeevani Auto) recommended me to remove R12 gas and fill it with R134 and also have the AC servicing done. Quote was for 5K. Somehow i wasnt sure if he wsa right, as MASS guys from mumbai said i would have to change the entire system. After repeated confirmations, i finally choosed to go ahead with the refill and servicing.
Surprizingly the output turned out quite good. Apart from the engine load the cooling seems to be much better (in this heat of May). I would suggest get ur AC serviced and ask if the gas can be changed.
dar3dev|l is offline   Reply With Quote
Old 12th May 2010, 11:23   #4
Jaggu's Avatar
Thanked: 7,477 Times
How much has the AC and car run? Kms i meant. If it has done more than 80-100k time for a complete clean up and overhaul. Sometimes a complete clean up of cooling coils that sit inside the dash helps.
Old 12th May 2010, 12:58   #5
ajay2233's Avatar
Default Thanks
@Jaggu
It has done around 140000 kms. It is being repainted and I wanted to fix the AC also.
@greatmana,
I will check out the shops at peters road. will post the rates soon.
@Daredevil,
will find out what is the gas currently used
more inputs wil be of great help to me.
Old 12th May 2010, 13:02   #6
Jaggu's Avatar
Take it to an AC expert and do a complete clean up and re-install.
Old 12th May 2010, 13:06   #7
Thanked: 24 Times
Zen has a very weak AC to begin with, suggest you try and find out how much it would cost to switch to R134 gas system. In the existing setup, changing the Compressor is the only option, which will increase the cooling a bit, but will never be able to be AC systems that come now a days with the R134 gas.
musicmanaman is offline   Reply With Quote
Old 13th May 2010, 09:19   #8
b_ambat's Avatar
Thanked: 108 Times
Hi Bro, don't fill R134 gas in your current system because R134 works in a much higher pressure and it will damage the compressor. If you are planning to fill R134 you have to choose the compressor accordingly.
I suggest you to check with a good A/C mechanic first.
b_ambat is offline   Reply With Quote
S-Zen?(Swift engine in a Zen) raghuram.cg Modifications & Accessories 14 21st September 2008 10:52
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
No more ZEN for Zen Lovers abhibh The Indian Car Scene 65 8th May 2006 17:17
Used Zen vs new Zen shuvc Hatchbacks 12 18th August 2005 19:16
E-Zen & B-Zen.... MustangMan The Indian Car Scene 3 2nd July 2005 21:27
