Old 16th May 2010, 21:21   #16
Thanked: 2,410 Times
A loose solder / connection somewhere, most likely in the fuse box. Causes sparking when the current is on, and after a bit the metal components manage to conduct.
Do modern looms use solder?
Sutripta
Old 16th May 2010, 21:54   #17
SS-Traveller's Avatar
Thanked: 11,631 Times
I wouldn't be sure who's been inside that fusebox earlier. Also, I would use the term solder loosely to indicate the fusing of a wire with a clip. Would expect these to be spot-welded.
Old 16th May 2010, 22:16   #18
Loose solder/ solder loosely! Not Freudian, but am sure a slip/ association of some sort for which you doctors have a name
Sutripta
Old 16th May 2010, 22:37   #19
Sutripta
No, I'm not dyslexic.
It is characterized by difficulties with accurate and/or fluent word recognition, and by poor spelling and decoding abilities.
These difficulties typically result from a deficit in the phonological component of language that is often unexpected in relation to other cognitive abilities and the provision of effective classroom instruction.
Secondary consequences may include problems in reading comprehension and reduced reading experience...
Source
Very Strange Overheating Issue, Please Help johnruben Technical Stuff 34 3rd December 2010 02:22
Strange Issue with my Autocop XS 8500/8550 johnruben Technical Stuff 5 2nd September 2010 19:43
strange Ac issue in Indica V2 dls... need help PRODENT Technical Stuff 1 20th October 2009 19:08
Ford Ikon 1.3 - Strange Issue ! ford_honcho Technical Stuff 5 31st August 2009 21:19
I am facing strange issue with my car AC? vinayvtec Technical Stuff 14 8th October 2008 14:27
