| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. | |
| | #17 (permalink) | |
| BHPian | Quote:
__________________ Regards, Bruce _______________________________________ If at first you don't succeed, skydiving is not for you! | |
| | #18 (permalink) | |
Sound is just a wave like any other waves. If it is moving in your direction and it is in human audible frequency range, you hear it. If it is in higher frequencies, you don't hear it. Remote sends a wave that is way beyond the human audible frequency, hence you don't hear it. Besides, it sends an encrypted signal probably packaged in a carrier frequency. Ok, now we are getting too technical here, not something I intended.
| | #19 (permalink) |
| BHPian | Samurai makes me put in my thoughts too! I have to agree with Samurai, technically it does not work. If it works, how does it work? My 2 cents.. I think the answer lies in two phenomenon. EMI(Electro magnetic interference) and Hormonics! The remote transmitter is an intentional antenna. It also has signal which may be audio frequency (I am guessing) and a carrier, Radio Frequency. And the telephone may be a unintentional antenna, which is capable of recieving the interference and letting in the audio signal or its hormonics into the system. These signals may get carried along even wothout a notice. And at the car end, both cel phone and autocop reciever are intentional antennea which interfere with each other whose frequencies or their hormonic frequencies match somewhere which make them probably work. Remember, Hormonics do not have the same signal stengths as original signals. So airfoil's experiments might have woked sometimes and sometimes not!
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #21 (permalink) | |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| Quote:
I had read this article a whlie back and i think its total BS.
__________________ ______________ __________ ______ __ | |
| | #22 (permalink) | |
All cellphone transmissions are done after A2D conversion which will eliminate any possibility of stray harmonics beyond 4KHz frequency. Therefore they can't get a free ride.
| | #24 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
also i think DRC may be right; the freq being used is the modulating freq not the modulated freq. Last edited by navin : 19th October 2005 at 23:19. | |
| | #25 (permalink) | ||
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. | ||
| | #26 (permalink) |
| BHPian | I barely see any chance that this may ever work. The reason is all good quality remote control systems use code-hopping technology to provide security that only the intended pair of Tx(Transmitter=Remote here) and the Rx (Receiver=base Unit here) matches and the matched pair only unlocks the system. The Code-hopping by the very nature of it works much out of the upper audio frequency ceiling capable on a cell phone or a wireline tel system(4 Khz). Even after this, the hopping code is modulated by a high frequency carrier and sent by the transmitter. So even the harmonics of it working out a correct code can be ruled out completely. I'm 101% confident that this is just a hoax...
__________________ dentalteam.org Last edited by Digital Vampire : 19th October 2005 at 23:49. |
| | #27 (permalink) |
| BHPian | Myself has landed up in this mess of keeping the key inside and getting the car doors accidentally autolocked. And the most wierd part is it happened to me during my honeymoon trip at a remote hill station in Kerala. After having spend nearly 20 minutes in the bitter cold exhausing all the known tricks (even the safety pin tricks seen in movies...lol)waiting for some help in the deserted hillside road, I decided to finally break open the glass. Just then one tourist taxi came and the driver happened to know how to "lift" cars. In 2 minutes flat, he opened the door with simplest of the tricks which even defeated my 12K worth security system. For people who are curious to know the trick: Just lift the glass beading and slide a thin tree stem or even a plastic ruler to release the latch inside... it is as simple as that. It was a revelation to me and a lesson well learnt. Never enable the autolock feature and never leave anything too valuable inside the car. There is every possible chance that it can be lifted very easily. Use Engine Immobilizer to safeguard the car itself from being lifted this way. But again i heard that even the engine immobilizer can be fooled easily. After this incident, i've tried this on my second car and my friends car and it all worked the same...You can simply open the car door with a Plastic Ruler!!!! Thought i took a little more than 5 minutes than the "expeienced" Taxi Driver. many thanks to him anyway... Take care.. It is your hard earned money...and companies dont care a damn about security. I wonder whether this is kept as a feature rather than a design flaw to get inside in such emergency situations. But unfortunately the crooks know this and now you all too ;-)
__________________ dentalteam.org Last edited by Digital Vampire : 20th October 2005 at 00:21. |
| | #28 (permalink) |
| BHPian Join Date: May 2004 Location: Delhi/Noida
| Hmm, didn't think this topic would get so technical. One of the links posted states that obviously the frequencies of the waves emitted froim the remote are different from the ones emitted by the phone. In addition, most high-end car security systems change their frequencies regularly. |
| | #30 (permalink) |
| BHPian | Hmm!! Well I have not tried this either..! I am not proposing a theory here but, just thinking aloud! I guess (only guess) the signal may still be in audio spectrum. Remember, in the whole experiment we dont care to hear in the phone. Have you ever heard of a crazy noise on the speaker either in the music system or an other phone when a cell phone is nearby and you recieve a call on cell phone? I think this means, cell phone is capable of producing broad spectrum noise in all possible hormonics of carrier and otherwise. Bottom line, this phenomenon may work, just because it is not a perfect world! ![]()
| Thread Tools | |
Similar Threads | ||||
| Ever locked the cars with Keys inside? | Surprise | Shifting gears | 89 | 28th March 2008 15:21 |
| Car Keys | vid6639 | Shifting gears | 13 | 3rd March 2008 12:47 |
| Safari 2.2 Ad - Why/how is the front wheel locked? | Venkatesh.C | Technical Stuff | 38 | 26th October 2007 12:53 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
