Thread Tools
Old 19th October 2005, 17:17   #1 (permalink)
bruce's Avatar
Default Locked the keys in the car
Some body forwarded me this; but was unsure if this really would work, has anyone tried it?
read below.....
Locked the keys in the car? Your car has remote keys?
This may come in handy someday. Good reason to own a cell phone: If you
lock your keys in the car and the spare keys are home, call someone on your
cell phone. Hold your cell phone about a foot from your car door and have
the other person at your home press the unlock
button, holding it near the phone on their end. Your car will unlock. Saves
someone from having to drive your keys to you. Distance is no object. You
could be hundreds of miles away, and if you can reach someone
who has the other "remote" for your car,you can unlock the doors (or the
trunk).Editor's Note: *It works fine! We tried it out and it unlocked
our car over a cell phone!"
Bruce
__________________
Bruce
_______________________________________
If at first you don't succeed, skydiving is not for you!
bruce is offline   Reply With Quote
Old 19th October 2005, 17:21   #2 (permalink)
?ushk@r's Avatar
Cell phone!! Unlock!! Did u try that Bruce?
__________________
?ushk@r
?ushk@r is offline   Reply With Quote
Old 19th October 2005, 17:25   #3 (permalink)
http://www.breakthechain.org/exclusives/phonelocks.html
http://www.snopes.com/autos/techno/keyless.asp
This is total nonsense
Abhay is offline   Reply With Quote
Old 19th October 2005, 17:26   #4 (permalink)
Conan's Avatar
It might work if the signals are sound waves, not sure but.
Conan is offline   Reply With Quote
Old 19th October 2005, 17:28   #5 (permalink)
viper's Avatar
Hey Bruce,
Only a part of the article or ad was forwarded to you. This was part of an article on a vehicle security system cant recollect the name though.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 19th October 2005, 17:41   #6 (permalink)
How can u lock the car if the remote is in the car??
i am assuming that the remote is part of the key chain!
Rishi is offline   Reply With Quote
Old 19th October 2005, 17:44   #7 (permalink)
shuvc's Avatar
I faintly recall this being discussed in some thread earlier
__________________
PIGZILNKILJBSCOMB
Old 19th October 2005, 17:54   #8 (permalink)
airfoil's Avatar
I've tried this and it works!
A little bit of trial & error is involved - it worked for me when I put the cell phone on speaker. I use the Autocop system.
airfoil is offline   Reply With Quote
Old 19th October 2005, 17:57   #9 (permalink)
viper's Avatar
Hey Bruce,
Check out Irwin's post on page 3 under Technical Stuff under the heading Car Security System. The product is called Microvbb.
Viper
__________________
Old 19th October 2005, 18:09   #10 (permalink)
I think you have a point!
Boom Shiva is offline   Reply With Quote
Old 19th October 2005, 18:22   #11 (permalink)
Does it work on sound waves?
__________________
Drive fast, but drive safe.
RX135 is offline   Reply With Quote
Old 19th October 2005, 18:52   #12 (permalink)
Samurai's Avatar
Ok, let me add my piece. I have extensive experience designing/developing telephony software, also I graduated as E&C engineer.
Here is one reason why this can't work.
When sound energy hits the mic in the cellphone, the membrane vibrates and converts the sound energy into electrical pulse/energy. Now, the human voice falls within 2KHz-4KHz frequency. Therefore, in order to reproduce it faithfully we only need to sample it at twice the highest frequency(Nyquist frequency). That means the voice is sampled at 8KHz or 8192 times every second. This process is called A2D or analog to digital conversion. After this your voice is just a stream of zeros and ones which gets transmitted to the destination. On the other side the process is reversed (D2A conversion and then to speaker membrane) to reproduce the sound.
As you see, if the frequency in question is greater than 4KHz, the chances of that passing to the other side is mathematically impossible. And I believe the remote locking frequency is definitely outside the audible frequency.
__________________
Samurai
The notchy gearshift of GV has become buttery smooth after I started driving the Jeep.
Old 19th October 2005, 19:11   #13 (permalink)
I have the Maruti Nipppon system. This can be programmed so that the car doors automatically lock 30 sec after the ignition is turned off and the last door closes. You could theoretically have the key in the car in such a case.
I was warned by the dealer to be careful I have the key with me, so I have disarmed this feature, precisely to avoid being locked out.
__________________
Hyundai Getz 05
Baleno Vxi 05
filcord is offline   Reply With Quote
Old 19th October 2005, 19:45   #14 (permalink)
Didn't get this last part which you said is impossible. If let's say, the frequency is 5KHz, can't we sample at 10KHz and pass it on?
__________________
Old 19th October 2005, 19:48   #15 (permalink)
Xsailor's Avatar
Default Ditto
Ditto that, filcord.
Useless feature that. I got it "cancelled" on the Nippon of my Santro.
__________________
Lt.Col.Frank Slade: You're in no position disagree with me, boy. I got a loaded .45 here. You got pimples.
Xsailor is offline   Reply With Quote
Thread Tools
Ever locked the cars with Keys inside? Surprise Shifting gears 89 28th March 2008 15:21
Car Keys vid6639 Shifting gears 13 3rd March 2008 12:47
Safari 2.2 Ad - Why/how is the front wheel locked? Venkatesh.C Technical Stuff 38 26th October 2007 12:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
