Old 17th May 2010, 23:22   #1
Thanked: 36 Times
Default NHC engine revv limiter not working?
Recently i got my NHC serviced at 20k, i has felt jerking at rpm of around 1100-1200, but my dealer refused to accept the problem so i asked him to scan my ECU and as it was covered in warranty i was not charged, yesterday i has a chance to drive it on highway and i felt that the jerking to be still present, but the acceleration has improved and engine is now a lot smoother, but to my surprise the engine crossed 6000 rpm limit in 2nd gear, normally the limiter would cut the rpm at 6k earlier but this time it almost went 6200-6300 before i realized that limiter didn cut in. i haven dared to try it again as i know it would damage engine.
i wanted to know if dealer has spoiled my ecu setting or might have just changed them to VTEC one? and how come theres so much difference in acceleration?
drsnt is offline   Reply With Quote
Old 21st May 2010, 11:01   #2
Thanked: 89,156 Times
You know, some of us would pay good money for that . Increasing the revv limit, that is.
I swear my Vtec revved to 7,400 rpm on some occasions, and Shantanu had reported the same with his car. This was only temporary though. I suggest you drive a couple of kms; good chance that the ECU was reset and still in a learning phase. However, if the limiter still doesn't kick in, and you aren't comfortable with that, have the authorised service center look it up.
Just for the record : As long as you have your oil changes on time, redlining a petrol engine once in a while hardly makes a difference to its long-term reliability. I high-revved my OHC Vtec (running on Mobil 1) for more than 1/2 its life, yet at over 70,000 kms, it showed 106 BHP at the dyno (still a healthy engine). Modern engines are built to last over 2,00,000 kms. Again, basic maintenance practices like timed oil changes, keeping the revvs low when cold etc. are more important.
Old 21st May 2010, 12:35   #3
pranavt's Avatar
Thanked: 272 Times
With the stock cam on the OHC VTEC, you're already running out of power at 7.1k RPM. And going a good amount beyond that on stock valvesprings will most probably destroy your valves and whatever they come into contact with. I actually lowered the redline on my OHC from 7100 to 6900 once I had my ECU connected to my laptop.
Don't know the redline of the NHC, but if you feel you can overrev, don't take it beyond the stock redline and get it checked soon.
Old 21st May 2010, 12:50   #4
ghpk's Avatar
Thanked: 192 Times
Is OBDII cable the method you used ?
or you have any special tools/cables to do it ?
Old 21st May 2010, 12:57   #5
dhanushs's Avatar
Thanked: 4,054 Times
very true .
And regarding rev limiter I guess for NHC its safe till at-least 6.5k. If the limiter doesn't cut in even at much higher rpm's, parts may not withstand the additional stress generated. Better get it checked.
Old 21st May 2010, 13:19   #6
pranavt's Avatar
Thanked: 272 Times
Special tools on a chipped and remapped Honda P28 ECU.
Old 23rd May 2010, 04:13   #7
tacho's Avatar
Anyone knows the factory rev-limit of an NHC? OP, Is the rev-limit mentioned in the owner's manual? Where is the redline marked on the tachometer?
tacho is offline   Reply With Quote
Old 23rd May 2010, 21:03   #8
ssjr0498's Avatar
Thanked: 118 Times
Do you mean peak power, yeah maybe! (peak power on our cars come at 6800rpm if I am not wrong) But otherwise,its not like the car will start running out of power. Technically, if you have the correct fuel map and ignition map to support, you will definitely not feel out of breath.
I have been taking my OHC Vtec to 8000rpm almost every second day, on stock valvesprings, stock cam. Nothing happened. As a matter of fact, I know of many OHC's running to 8000rpm with the stock cam and springs.
Just my 2 cents, dunno abt others.
Shrey
ssjr0498 is offline   Reply With Quote
Old 23rd May 2010, 21:31   #9
pranavt's Avatar
Thanked: 272 Times
Originally Posted by ssjr0498 View Post
Shrey
Yes, peak power. We both know how long it takes to bump up the revlimit with our fancy ECUs, so I'll just get to the practical bit about saving the engine. A few hundred extra revs for a few seconds is definitely not worth the broken parts that can result from it. And with open loop, iffy maps beyond the stock revlimit and no knock sensor, I do not wish to test the thermal efficiency of my engine's cooling and ignition system.
All you enthusiastic drivers : Do NOT OVER-REVV GTO Technical Stuff 116 3rd September 2011 20:21
Over revving MPFI Zen Engine( revv limiter doesnt cut at 6000 rpm!!) speedsatya Technical Stuff 4 30th October 2010 15:21
Ractive Tachometer 3.5'' does not cross 3000 RPM on Max Revv bugboy180 Modifications & Accessories 21 23rd January 2009 00:11
No Rev Limiter on the Getz CRDi???? anarchist Technical Stuff 10 13th October 2008 22:31
