Old 18th May 2010, 22:01   #1
Default What is the red light flashing on alarm switch on Swift?
After locking the swift using the 'lock' button on the remote, i can see the red light flashing on the Alarm switch. What is that for? Am I missing something?
Thanks for your help,
Narayanan
NVI2112 is offline   Reply With Quote
Old 18th May 2010, 22:19   #2
sandeepmohan's Avatar
Thanked: 1,900 Times
Please read the manual. The newer lot of cars from Suzuki have an ICATS security system installed. It could be a theft deterrent indicator that is flashing.
On the old Ford Fusion the key fob has a chip built in and a similar light starts flashing in the instrument cluster only when the key is with you. Not otherwise. So if you approach the car without the keys, it does not flash.
Try walking up to the car without the keys to check if this light keeps blinking. If it still is it could just be a theft deterrent system.
sandeepmohan is offline   Reply With Quote
Old 19th May 2010, 09:37   #3
Hi Sandeep,
tried approaching it without the keys and can still see the red blinks on the alarm switch. surprisingly, there is no note about the Alarm switch in the Swift manual !
guess will have to drive down to a garage and clarify my doubt!
Old 19th May 2010, 10:34   #4
akash_m's Avatar
Thanked: 88 Times
The red flashing light on the alarm button indicates that the vehicle is 'Armed', or on other words, the security system of the car is active. The panic alarm, ignition cut off etc are 'on' so to say.
If you lock the car manually, i.e using the key, this red light wont flash, showing the the vehicle is not 'Armed'.
akash_m is offline   Reply With Quote
Old 19th May 2010, 12:39   #5
Thumbs up
Thanks Sandeep & Akash for the information.
I too had visited the nearby MASS and spoke to the advisor regarding this. which ofcourse matches what you both have explained to me.
MODS kindly close this thread as my query is answered.
Thanks for the support.
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 81 28th May 2018 14:29
Swift DZire 2009 Immobiliser Lock Light Flashing vigsom Technical Stuff 7 10th June 2012 22:52
AC Switch OFF or Blower Switch OFF Peter Technical Stuff 24 29th June 2011 12:02
4L light keeps flashing in Safari Dicor Edit: now fixed jyobeb 4x4 Technical 53 25th March 2008 13:00
FLASHERS (FLashing headlights n othrs like in cop cars )where do u find it in mumbai? karizma_devil Modifications & Accessories 1 18th October 2006 18:44
