Old 28th May 2010, 19:39   #46
Thanked: 2,459 Times
I am afraid to say , your local mech guys are just trying to do a patch up job on your car.
On such instances, you need to
1) Change set of piston rings
2) Get the Valve grinding done
3) Change the headgasket
4) Change the valve stem seals
5) A new engine and timing belt replacement
6) Timing belt tensioner replacement
7) New engine sump filter
8) Change engine oil and oil filter
9) Change the thermostat
10) Install new spark plugs and plug leads
11) Clean / overhaul the carb
12) Flush the radiator with soap water and fill coolant and distill water mix.
All the above might cost a bit more, but certainly would have given you a lot of peace of mind.
Old 28th May 2010, 21:59   #47
nitrous's Avatar
Thanked: 282 Times
Did you check your head for warpage?
Old 30th May 2010, 21:17   #48
Mpower's Avatar
Thanked: 1,682 Times
LOL, Pavan. Spoken like a true restorer.
But, most owners of 15 yo cars just want to keep the going not getting it into concours condition.
Old 1st June 2010, 12:47   #49
Captain Slow's Avatar
Thanked: 650 Times
Originally Posted by Shashank.A View Post
This is the beauty of good old Esteem. Super cheap to maintain, and ever reliable.
Indeed!!
Originally Posted by ramzsys View Post
Regarding the removal of the thermostat valve- it is not advised and is against the long term health of the engine.
Nope nothing was removed.
Originally Posted by Mpower View Post
Did they figure out why it overheated in the first place. Is your thermostat OK? Is your temp guage OK?
Try synthetic oil for engine smoothness.
I don't think so. The thermostat seems ok. Every time I run the engine for awhile the temp gauge goes up to the half way mark. Doesn't go above that.
I have replaced the engine oil and oil filter with Shell HX5.
synthetic oil only once I know for sure there is no more oil leak/
I know Pavan,
The mechs at this shop have started laughing every time I go in.
They tell me that car is running fine so let it run!
On asking them if the piston rings need replacement they laughed and said don't bother with something that isn't broken!
If the engine starts and runs the mechs jobs done! they don't care about smaller details.
They haven't cleaned the radiator properly as I can still some oil+coolant in it!
Pavan, how much would a job like this cost? Any good garage you can recommend for this kind of job?
Head seemed fine according to my mech. But come to think of it I guess he just did a patch up job and doesn't know much
Mpower
I guess I'm the exception here! I try and keep it at its best as much as possible.
Really strange! none my rides have been spotted! all of them have team-bhp stickers!
As of now I got the oil and oil filter changed. The car seems to be running fine. But now there seems to be a lot of vibrations. The engine seems to have lost its original smoothness. It doesn't sound as silent as it did before this happened.
Asking the mech was pretty much useless. He tells me run the engine for a while and it will be fine.
Captain Slow is offline   Reply With Quote
Old 1st June 2010, 12:52   #50
Jaggu's Avatar
Thanked: 7,470 Times
Goto Nexus and ask them to do a half engine overhaul.
Old 1st June 2010, 14:49   #51
mooza's Avatar
Thanked: 243 Times
Sorry for the OT, but could the use of synthetic oil reduce engine vibrations in a diesel engine ? If yes, I could try it for my Scorpio.
@Captain Slow, you would find the link below quite interesting :
http://www.team-bhp.com/forum/techni...ge-well-2.html (piston rings - how do i know? (head gasket change as well))
mooza is online now   Reply With Quote
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
My Chevy Cruze broke down! Problem with the turbo hose clip brijesh1977 Technical Stuff 16 19th May 2015 11:35
Any ideas to improve car safety? freewheelburnin Technical Stuff 3 30th January 2010 00:01
Dataone Usage Finder: Not working for past 1 month. Any Ideas khan_sultan Gadgets, Computers & Software 17 29th December 2008 17:49
New Wagon R Duo Broke Down shivkumar19 Technical Stuff 20 9th April 2008 12:21
