Old 21st October 2005, 00:15   #1
moralfibre's Avatar
Thanked: 6,533 Times
Post Help With Camber / Castor readings
Calling all techies...
I have a Zen and I got alignment/balancing done today at a well known workshop in Pune. Surprisingly the Camber readings show -2.15 (Left) and -2.10 (Right). I knew that something was wrong with the Camber as I observed that the wheels had started moving inwards from the top. The alignment guy told me that he can push in a bolt that is ground on the lathe but I refused to accept this modification as I knew a friend of mine faced lots of troubles with the slimmer strut bolt.
I have recently got new struts and bushes on the car so I can assure that this is not a suspension issue but is possibly caused due to bad roads and frequent bangs on pot-holes.
Can someone give me options that I have to get the tyres in place as I do not want to loose the inner tread of the tyres. P.S. The castor is also out of order due to the Camber positions.
How can I fix this?
Old 22nd October 2005, 05:34   #2
Mpower's Avatar
Thanked: 1,687 Times
What is the camber supposed to be?
Talk to you Maruti service center. They might have a special kit for aligning cars with wrong camber. Its not adjustable normally.
Also inspect your bushings and ball joints for wear.
How is your tire wear? Are you wearing the shoulders more
Old 22nd October 2005, 08:51   #3
moralfibre's Avatar
Yes I am wearing the shoulders more.
Old 22nd October 2005, 08:55   #4
viper's Avatar
Thanked: 9 Times
Thumbs up
Hey Moralfibre,
There is no harm in getting the "special bolts" normally termed as setting bolt. All wheel alignement people use this and is practically harmless if the correct stuff is used and solves the problem.
An authorised workshp will not do that as he is not allowed by the company. What would you rather do change a bolt costing couple of RS or free and solve your problem thereby saving your tyres from uneven wear OR changing expensive suspension parts which MAY NOT end up solving the original problem. Your call.
FYI I have fixed these bolts in my Esteem, Santro, Opel Astra, Swing and driven over bad terrain for 3-4 years without any negative effect caused due to the setting bolt.
Viper
viper is offline   Reply With Quote
Old 22nd October 2005, 09:02   #5
moralfibre's Avatar
Hey Viper I am in two minds over the setting bolt as I doubt their strength. Is there any other alternative I have?
Old 22nd October 2005, 09:06   #6
viper's Avatar
Thanked: 9 Times
I'm not much of a technical expert but in my past 12 years of doing up cars nobody I have come across has offered/given another alternate.
If you doubt their strength either get it tested or get one made . Doesnt take much to get it made. However you have no reason to worry unless you intend to drive your car aka rally style over terrain not meant for street cars.
Go ahead and do it if not comfy in Poona do it Bombay I can recommend a few places who keep genuine stuff.
Viper
Old 22nd October 2005, 09:13   #7
moralfibre's Avatar
Is it true that some kind of metal pieces are hammered into the gap caused by the thinner bolt?
Old 22nd October 2005, 10:34   #8
ananthkamath's Avatar
Thanked: 63 Times
Moral fibre, as viper said there's no harm in using what are known as "cam bolts" to adjust the camber. These come as standard on many, if not all, cars with strut suspension.
If they don't come as standard, you can get what's known as a "service strut" which has an oversize hole on one side of the lower strut mounting bolts. With this you can adjust camber.
Castor cannot be adjusted but if your castor is out even after correcting the camber, your lower arm may be bent.
ananthkamath is offline   Reply With Quote
Camber, Toe and Castor. Know it now and drive smoother. kapiljolly79 Technical Stuff 8 8th July 2011 23:48
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Perplexed with camber readings swathyd Technical Stuff 12 23rd June 2008 21:47
Funny meter readings aZa Shifting gears 6 13th July 2006 13:52
Wanted Castor based 2t oil or OWS 2t cbr1000f Shifting gears 0 20th January 2006 11:28
