Old 25th May 2010, 12:47   #16
mjothi's Avatar
Thanked: 216 Times
Originally Posted by karty_83 View Post
These caps are not well fitted. I guess it wont be too long before the rhs mirror loses its cap as well
Ok, if you are concerned about this, make sure you show the service guys clearly why you feel so. And probably they may agree. Either case, can you post some pics of this here?
Also, if you are sure of these being fitted so bad, send an email to GM with valid pics. Even if its not going to be useful for you, I am sure this will be checked for sure.
mjothi is offline   Reply With Quote
Old 25th May 2010, 13:04   #17
MAS
MAS's Avatar
Thanked: 1,211 Times
Karty,
This is a very small issue. Just go and get it fitted and enjoy your ride. Solutions are simple and in this case not expensive at all.
Just ask them to use some glue (not super glue) when they fix them or else you would end up losing them again.
I have not heard of any other Spark guys complaining about this. Is it a one-off problem or hereditary to all Sparks.
MAS is offline   Reply With Quote
Old 25th May 2010, 13:13   #18
karty_83's Avatar
Thanked: 165 Times
Fine, i ll post the pics soon. In between, i bought the car from Trident. Can i get this fixed from Sundaram as they are close by ?
karty_83 is offline   Reply With Quote
Old 25th May 2010, 13:14   #19
karty_83's Avatar
Thanked: 165 Times
I am not sure about that, but two other sparks within the forum have faced the same problem.
Old 25th May 2010, 13:44   #20
SPARKled's Avatar
Thanked: 407 Times
Don't fret too much over it. the rest of the OVRM assembly is pretty secure and wont fall off easily. If the dealer is far off, no need to go there just for this. Get it done at the next service. That is what I did.
SPARKled is offline   Reply With Quote
Old 25th May 2010, 15:26   #21
ghpk's Avatar
Thanked: 193 Times
Go to any dealer, they'll give you the cap, and most probably to win a new customer the nearer service center might go an extra step for you.
Little Spark of Happiness has arrived - Chevrolet Spark LT JRD Test-Drives & Initial Ownership Reports 27 15th November 2008 13:44
silencer fallen off. help!! kutlee Technical Stuff 6 11th October 2007 20:34
Chevy Spark...Chevy U-VA...comparative test drive report! omar1310 Test-Drives & Initial Ownership Reports 0 7th June 2007 11:59
The curse has fallen upon Rossi! turbo_v12 Int'l Motorsport 10 24th May 2006 01:26
