| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jun 2004 Location: Navi Mumbai / Bangalore
| today i drove my carb zen after a gap of several months and i was trying to push it to see what top speed it can achive...and i could take it to 140 kmph max..also it seems to have a wheel alignment problem cos when i brake it hard it pulls to the left side...the car also seems to be revving less freely...i am going to take it for a check up tommorow will proberbly get the carb and the air filter cleaned...what could have gone wrong.? and i am also planning to use a synthetic engine oil..which one is recommended? ..what is the max speed a carb zen can achive?.
__________________ ------------------------------------------------ |
| | #2 (permalink) |
| Senior - BHPian | Your brakes are grabbing...thats the reason for the pulling to the left. When was the car last serviced? How many kms has it covered? A normal service and tune up should have things back to normal. Mobil 1 seems to be the widely recommended brand for synthetic oils. Top speed of 140 seems correct...but others would know better...as i've never owned the carb zen. Drifter
__________________ Slow Everything Down And Feel Like God - Tata Safari |
| | #3 (permalink) |
| BHPian Join Date: Mar 2005 Location: bangalore
| I guess a carb zen can achieve a top-speed of 150kmph on speedo...coz I've read that the top-speed gain is arnd 8kmph on the mpfi zen than the carb zen...i have touched a max of 155kmph on my mpfi zen and it was still going pretty strong.... guess u should push a little more hard...try after the service!
__________________ There is more to life than incresing its speed! |
| | #4 (permalink) |
| Newbie Join Date: Oct 2005 Location: chennai
| the reason for ur car pulling 2 one side is worn out brake pads, n not wheel alignment get them changed . about the engine not revving freely, do wat ever drifter had suggested n ur zen will burn the tyres as usual.....
__________________ FLOOR THE PEDAL N GRAB THE MEDAL |
| | #5 (permalink) |
| thank you guys for ur opinions..got the wheel balancing and alignment done today and now it is running like a dream...also got the right side drive shaft replaced..the brakes seems to be working fine..today when i removed the air filter i found that the carb was oily , is this a normal occurance?.
| | #6 (permalink) |
| BHPian Join Date: Jul 2005 Location: mumbai
| i got a very stupid question for you gurus. is the k&n oe replacement filter an oil filter or air filter ? where can i get one for my carb zen ? what would the cost be like ? and what would the changes be ? and how long does it last ? Rev |
| | #8 (permalink) |
| Newbie Join Date: Jul 2005 Location: bangalore
| hi the k&n filters r usually for the air intake , u can place a k&n on the carb of ur zen , it wouldnt cost u much becaus u dont have to buy the whole assembly, and that would cost u any where around 3500 to 5500, and they surely improve the performance . |
| | #10 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Learning is a continuos job that keeps me busy. | |
| | #11 (permalink) | |
| Quote:
__________________ ------------------------------------------------ | |
| | #13 (permalink) |
| what is the specs of the mobil 1 which can be used in the carb zen..ie the viscosity?? where is it available in mumbai.
| Thread Tools | |
Similar Threads | ||||
| 99'ZEN carb to ZEN mpfi.... | Balram | Modifications & Accessories | 17 | 10th December 2006 08:04 |
| Carb Zen w/o the muffler | raghuram.cg | Modifications & Accessories | 8 | 18th April 2006 18:08 |
| 14" for 97 carb zen.... | sparco | Tyre & Alloy wheel Section | 14 | 16th June 2005 13:20 |
| vibrations in zen 97 carb. | heavy_foot | Technical Stuff | 11 | 30th May 2005 11:01 |
| the 90bhp+ carb zen | speedsatya | Modifications & Accessories | 4 | 14th February 2005 14:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
