Old 25th May 2010, 14:10   #1
Peter's Avatar
Thanked: 45 Times
Default ACCENT Engine vibration/chokeup on Petrol
Hello Team,
My Accent gls petrol has comeup with an issue all of a sudden that is quite worrying as the Car is hardly driveable on Petrol.
The car is installed with an LPG kit and hence can be run on Multifuel.
The Issue:
The issue is that when the Car is started or driven on Petrol there is feeling as if the engine gets kind of choked up at the very start and then suddenly accelerates as if the Petrol flow has just been increased..also if the car is driven at high speed then it continues to move smoothly... but when the speed is reduced then the choked feel comes in again and in case of hard braking then the car just shutsoff.
Another thing that Ive noticed is that when the car is idling the engine vibrates intermittenlty as if someone is witholding the fuel flow or something to the engine and the RPM is at 500/600 and never goes beyond this whereas the normal rpm reading previously would always be at 1000.
And for the most interesting fact...The Car runs/idles smooth on LPG.. no issues on LPG whatsoever and the RPM is at normal reading as well which is 1000, performance is normal on LPG as well, somehow its only on Petrol that the issue is occuring.
Things done so far to resolve with no success:
Replaced spark plugs / no success
Cleaned the Injectors / no success
Replaced the fule pump and filter / no success
The local mechanics are now at a loss to figure out as to whats the issue on Petrol as on LPG everything is just fine.
Can you please share your inputs/ suggestions on this issue ?
Any similar occurences of such type with anyone?
Please advice,
Peter.
Peter is offline   Reply With Quote
Old 25th May 2010, 15:03   #2
Thanked: 660 Times
since you have changed and cleaned most of the suspected parts.
Here is a simple task you should do. Clean the tank and fuel lines.
Old 25th May 2010, 16:15   #3
Peter's Avatar
Thanked: 45 Times
Thanks for the reply SirAlec..
The tank was very clean when inspected , since the fuel pump was removed the tank contents were very much visible and hence can confirm on its status... the fuel line has not yet been looked at though.
Am just wondering whether this could be the likely problem? is it normally easy to clean the fuel line or replace ?
Any ideas team ??
Old 25th May 2010, 21:07   #4
Thanked: 660 Times
Its a easy job. You just need a high pressure air compressor.
Old 26th May 2010, 11:50   #5
To add to it, is yours a closed loop kit with a lamda controller? if so, do check the tuning on the lamda controller - the tuning on it also controls petrol performance including idling on petrol etc.
the lamda controller is connected to a laptop and many of the parameters are then set separately for petrol and for lpg.
harsha.cs1 is offline   Reply With Quote
Old 27th May 2010, 11:05   #6
mohit333's Avatar
I faced a similiar problem but it was resolved by replacing the relay for the fuel pump. Just check if that's the issue with your car.
mohit333 is offline   Reply With Quote
Old 27th May 2010, 13:56   #7
Peter's Avatar
Thanked: 45 Times
Team,
Mine is an Open Loop Kit of LPG..
The fuel line has been cleaned... no success
The technician has informed that the relay is no problem...
Any ideas/suggestions on this issue ?
Old 27th May 2010, 16:21   #8
Thanked: 660 Times
Then i suspect the LPG kit mainly petrol solenoid valve and emulator. Emulator remains on even in Petrol mode.
Old 29th May 2010, 11:52   #9
Yes possibly. In fact, I have been facing the opposite trouble.
My car sometimes idles very low and turns off on LPG. When revved high, it does ok. and it runs great on petrol. Typically, I see that this happens due to the LPG filter getting choked with dust. But i sometimes wonder if there could be any other reason as well - coz the filters ideally need to be cleaned only once in like 7.5k kms. But i end up doing it a lot more often like in 2.5K kms.
Old 1st June 2010, 18:47   #10
Peter's Avatar
Thanked: 45 Times
Team,
The issue is now resolved
Somehow one of the wires going from the engine to the ECM via a relay ( LPG kit ) was cut, the wire was rejoined and the ECM reset via a battery disconnect and the Car is purring as normal now.
Thanks for all your help.
Peter.
Old 1st June 2010, 19:00   #11
gigy's Avatar
Thanked: 41 Times
do you have more detail on this wire, where was it joined to the ecm circuit?
Old 5th June 2010, 22:38   #12
Thanked: 660 Times
Originally Posted by Peter View Post
Team,
Peter.
Its definitely the cable from emulator to ECU, that fools ECU when running in LPG mode of different sensors signals.
Vibration in Accent CRDI badri Technical Stuff 9 29th December 2008 18:15
Baleno Engine Vibration and Sound @ 1600 RPM Traveler Technical Stuff 11 25th October 2008 20:16
Scorpio 2.6 non crde mild engine vibration Mohnish Technical Stuff 23 13th July 2008 19:39
Noise and vibration in Baleno engine sans33 Technical Stuff 14 20th June 2008 18:42
Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL DieselFan Technical Stuff 36 2nd May 2007 11:37
