Old 30th May 2010, 17:37   #16
Gilead's Avatar
Thanked: 21 Times
This procedure is recommended in the Fiesta owners manual. It says the car should be raced above 3000 RPM for at least 30 seconds once a week. It doesn't do anything to the ECU. It clears the exhaust soot and makes the car smoother to drive.
GTO is right. A car that has never been high revved in its life will feel sluggish initially. Take the same car on a spirited highway run, and she will rev much more freely after that.
Gilead is offline   Reply With Quote
Old 31st May 2010, 14:41   #17
Epic's Avatar
Thanked: 424 Times
Originally Posted by josepeter View Post
Comon Epic, be a sport!
Abhay has found us the perfect excuse to rip! Let's not get into investigations here...Lets enjoy the tip religiously.
Hahahaha.... I am a sport alright. Just difficult to find roads for such spirited driving here in Mumbai and when I do, get pulled up by the law for speeding
Epic is offline   Reply With Quote
Old 31st May 2010, 18:02   #18
Thad E Ginathom's Avatar
Thanked: 8,374 Times
When I'm clearing out whatever causes that black smoke, I rev hard in 2nd. High revs, but no excessive speed!
This is not a substitute for an extended period of highway driving, though.
Old 31st May 2010, 20:16   #19
Thanked: 94 Times
Default Works for alto
I've been doing this since two months ever since I got a hard clutch to minimize gear changes. The clutch is still the same though the engine feels a little sprightly now. I just redlined her(or so I think) at a traffic signal by going over 30 in first much to the show of scared scooterists. IMO any engine should be allowed to fully flex all its muscles during its lifetime. In a sedatley run car, these muscles atrophy and give a hollow driving experience.
Mine definitely is better than my neighbour's now. Verified by him & me.
This is no sham as I initially presumed. It WORKS.
JustCause is offline   Reply With Quote
Old 31st May 2010, 21:32   #20
sachinj12's Avatar
Thanked: 162 Times
Applicable only to petrol or what?
Touched 70kmph in 1st gear once and felt guilty about it. This thread has brought some peace to me. Sigh.
OT: Mine is a VDI.
sachinj12 is offline   Reply With Quote
Old 31st May 2010, 21:40   #21
I guess you should go on feeling guilty about that!
No: mine's a diesel. I'd be quite worried if I got black smoke from a young petrol engine.
Old 31st May 2010, 21:49   #22
sachinj12's Avatar
Thanked: 162 Times
Saw the owner's manual. It said max speed in 1st should not exceed 45kmph (or in the whereabouts). My heart sank and to top it all, she had done 1300 on the odo when I did it.
A moment of passion and life long regret
Old 31st May 2010, 21:57   #23
You sound like the car got pregnant!
Old 31st May 2010, 21:58   #24
sachinj12's Avatar
Thanked: 162 Times
Looks wise, she is. I own the Dzire you see
Old 31st May 2010, 21:59   #25
narendra.vw's Avatar
Thanked: 402 Times
My explanation , when you go with high rpm in low gears say 3d gear the fuel injectors nozzles open fully. This helps in spraying fuel fully & cleaning the fuel line. Any carbon deposits on the injectors will burn away. At the same time piston rings become free of any friction. Stand still revving will damage engine. You can also try getting injectors cleaned and recalibrated .
narendra.vw is offline   Reply With Quote
Old 1st June 2010, 11:36   #26
Rehaan's Avatar
Thanked: 25,038 Times
This has been discussed several times before. Here are some of the threads :
Basic ECM Resetting
How fast does the ECU learn your driving style? (How fast ECU learns the driving style?)
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS
Is ECU Learning affecting my FE? (Is this ECU learning affecting my FE ?)
cya
R
Team-Bhp flooding your email? Solution posted here! Sahil Shifting gears 30 4th September 2017 21:04
Sluggish Swift, Edit: And other swift speed related queries pillainp Technical Stuff 90 8th September 2009 21:27
Sluggish Brakes on my Accent libre sito Technical Stuff 15 8th October 2004 19:19
Why is Suzuki India so sluggish? SLK The Indian Car Scene 7 10th June 2004 15:42
