Old 1st June 2010, 09:54   #1
100BHP's Avatar
Thanked: 475 Times
Default Help needed, Wagon R dangerous wobbling
I have a 2006 Duo LX wagon R. I got its tyres replaced at 51K (new tyres with tubes from Bridgestone - GP2, stock size). Earlier tyres from JK had no problem at all.
After that my woes started.
The car front wobbles up & down heavily (like jumping at its toes) at speed between 70 ~ 90 Kmph.
There is no vibration in steering wheel or side movement.
Rohan Auto, Gr Noida engineer told that it is tyre problem.
I got the tyres checked by Bridgestone technical person at their authorised tyre centre in Ashram, Delhi.
They had given no problem chit & said nothing can be done. (All tyres got wheel balancing done, tyre pressure checked).
But still the problem remains.
On advise, i got the front shockers changed with new & again the tyre alignment & wheel balancing done, but still the problem is there
My driving is mostly on expressway & these speeds are frequently achievable .
Last week i sent this car to Apra Auto, Okhla with a promise that this problem will be sorted out . They again did alignment & wheel balancing (foc) & sent the vehicle back, but still....no solution. Even after feedback about problem, now they are not responding (Maruti's troubleshooting skills are limited, i think )
Anyhow, the problem is still there.
Can you provide some pointers to this problem.
100BHP is offline   Reply With Quote
Old 1st June 2010, 10:57   #2
Jaggu's Avatar
Thanked: 8,693 Times
Have they checked other suspension components and have you tried swapping the tires front to back?
Old 1st June 2010, 11:14   #3
100BHP's Avatar
Thanked: 475 Times
Yes, the tyres were rotated front to back.
Can you elaborate on other suspension components pls ?
Old 1st June 2010, 11:23   #4
greenhorn's Avatar
Thanked: 1,519 Times
swap the tyres with another wagon R if possible
suspension bits = ball joints, steering rods etc
Old 1st June 2010, 12:20   #5
Jaggu's Avatar
And lower arms and balance rod with bushes. Check the brake discs also just in case.
Old 1st June 2010, 12:29   #6
100BHP's Avatar
Thanked: 475 Times
Thanks, but what could go wrong with the change of tyres only ?
Also, why this is happening in speed range from 70~90 Kmph ?
Shall the tubes be checked also for their form when inflated ?
Old 1st June 2010, 12:49   #7
Jaggu's Avatar
Change of tires can upset lot many old parts, including a worn out tie end which can start resonating with the springs. So unless you do a complete check of suspension and steering component you might not be able to find the culprit. And what about wheel discs are they in good shape?
Old 1st June 2010, 13:10   #8
kpzen's Avatar
Thanked: 1,655 Times
A LOT. Complete dynamics of the car can change with a set of tire change.
Tires are the only contact point between your car and the road.
I'm assuming it to be a tire fault and at that speed, the effect is getting amplified. Did u try speeds above 90kph ?
Did u change the tubes along with tires or are u running the old set ? if its the latter, then u need to get them checked as well.
PS: Lets go for a TD.
Jags
Why do u doubt the discs ?
The problem is not while braking and there's no noise.
Old 1st June 2010, 13:41   #9
Jaggu's Avatar
Small warp, making the wheels unbalanced and creating a resonation. Symptoms do point out to something resonating, thats why its happening in a particular speed range. What is it that is resonating, if the wheels are properly balanced?
Old 1st June 2010, 16:30   #10
100BHP's Avatar
Thanked: 475 Times
Jags
There is no resonance above 90Kmph (if its there, its not noticeable at all),I had driven at 110~ 120 few times.
Tubes were also changed with the tyres.
We can go for TD when you are not in your rocket
Thanks Jaggu for your inputs, I will talk to MSM for their check up, but it means there is potential problem with all cars which goes for tyre change ?
Help - MM 540 wobbling !!! prmd_cochin 4x4 Technical 12 12th January 2013 13:09
A few problems with New wagon R. Help needed ! akhilesh Technical Stuff 5 31st May 2007 15:33
wobbling after changing punctured tire paharino1 Technical Stuff 3 19th May 2006 18:43
Wobbling Problems humyum Technical Stuff 0 1st March 2006 19:05
Wobbling wheels on a new Viva Neel Tyre & Alloy wheel Section 1 11th February 2005 15:05
