Thread Tools
Old 31st January 2006, 00:10   #16 (permalink)
jat
As long as the engine is running, the turbo will also run and hence you will continue to hear. Idling is to reduce the rpm and stopping the turbo in shortest possible time, so that turbo does not get starved of oil. Once the mininum rpm and sufficiently low exhaust temp is achieved, keeping it running any longer serves no purpose. Revving will rev the turbo and thus it will run without any oil supply for longer time.
jat is offline   Reply With Quote
Old 31st January 2006, 23:21   #17 (permalink)
nitrous's Avatar
I do all this, but I still here the hum of the turbo winding down AFTER I've switched the Safari off...I've tried different lengths of idling time, but the hum is still there. Sounds nice, though.
Sounds exactly like a turbo timer. If u have this, u dont need to wait for that 60 secs after switching on/before switching off.
__________________
Maruti - Everyone comes home with rattles!
Old 1st February 2006, 15:19   #18 (permalink)
Sideways's Avatar
Originally Posted by dceite
I always have never understood this. Truck drivers, buses, and other big diesel vehicals always revv the engine while turning it off(or should i say just the moment they turn off)? Why is it so? Any technical reasons they are told to do so?
To answer your question specifically - Most truck and buses have air brakes. This air is stored in a tank and needs to be charged and therefore these guys rev the engines before they stop and just after they start so that they have some kind of braking power. The rest of it is hogwash.
__________________
27th July
Sideways is offline   Reply With Quote
Old 1st February 2006, 15:44   #19 (permalink)
Team-BHP Moderator
Zappo's Avatar
Bah! So many different answers to the same question? Till now I gathered the following different reasons for why truckers rev before shutting down
  • To clean up the accumulated soot.
  • To have oil in the pipe. Helps them in restarting, without choke. (!)
  • This charges up the battery.
  • And the latest one is to recharge the air brake cylinder.
I can't remember but I think there are two more different reasons given there. Come on guys... Can we reach a mutual agreement on the reason for this now?
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 1st February 2006, 15:49   #20 (permalink)
Team-BHP Moderator
Zappo's Avatar
Originally Posted by tsk1979
As for carbon deposit in exaust pipe this problem is solved by once a month water treatment
Fill exaust pipe with water, and then rev engine hard. Washes out all the carbon, but make sure you dont do it in your backyard.
Wow! tanveer bro... that one floored me. You mean I should fill up the exhaust pipe with water? Really? How much water?! :-/ Won't that affect the engine if it gets sucked in?! Yeh koi desi jugad to nahi hai naa?
__________________
Old 1st February 2006, 15:50   #21 (permalink)
Sideways's Avatar
I can gaurentee that my answer is 100% right. Also this thread is a classic example of one thing being started and then getting completely diverted to a different topic. I think the mods should intervene and curb this sort of thing.
__________________
27th July
Old 1st February 2006, 15:52   #22 (permalink)
Sideways's Avatar
I sincerely suggest you dont fill your exhaust pipes with water to clean them out. If the water gets sucked in you are going to get a really huge bill
__________________
27th July
Old 1st February 2006, 16:05   #23 (permalink)
SLK
SLK's Avatar
Nothing to add.. to all that has been said.... but its not just truck/ diesel drivers... this is a common practice for many people doesn't matter if they drive a bike or a truck!.... but its wrong as far as I am aware.
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 1st February 2006, 16:25   #24 (permalink)
falcon's Avatar
OK, My reasons for doing so...
1. Both my vehicle batteries were in a terrible state... if I did not race the vehicle for at least a minute before turning them off, there was no way they would start later on... so I had to do it! I've changes both batteries now, so its not needed… but... old habits die hard.
2. The Classic's engine is in need of an overhaul, I burn nearly a litre of oil every month... And as a result, my exhaust smokes (thick black smoke) a LOT... A temporary solution (I plan to get the engine rebuilt soon) that I am currently using, every month, fill the entire exhaust with water and then rev the engine till all the water is pumped out... repeat this about 3 times, and then no more smoke!!! To facilitate filling water, I have got a 1/2 inch bend pipe welded at the engine end of the exhaust... Yes, one more thing I have done is make my fuel mixture very lean.... have lost out on power and pickup :-( but at least the PUC is within limits...
__________________
The price of freedom is eternal vigilence.
falcon is offline   Reply With Quote
Old 1st February 2006, 21:52   #25 (permalink)
True Zappo. I started this topic last year. Still not 100% clear on the answer though.
__________________
What goes around comes all the way back around
DCEite is offline   Reply With Quote
Old 1st February 2006, 23:47   #26 (permalink)
jat
IMO, the air is not going to be charged fully just by revving it, and if it does it can be done even when you start the engine. If you charge the air tank and then keep the vehicle, the air is likely to be drained out in old vehicles and hence it will be always better to charge the tank after starting rather than before stopping.
As far as I know, revving is always bad for the engines whichever way you see it.
RK
Old 2nd February 2006, 02:12   #27 (permalink)
Steeroid's Avatar
There is no sticker asking you to wait before switching off/after switching on (as seen in the Scorpios) inside my vehicle. I follow the process, nevertheless - I dont wait 60 seconds, but I wait for the engine to settle down to an even rhythm before I switch off / start moving the vehicle. The few extra seconds dont mean much to me, but it MAY mean something to the engine....
__________________
Steer
Where all think alike, no one really thinks very much.
Steeroid is offline   Reply With Quote
Old 2nd February 2006, 12:34   #28 (permalink)
Sideways's Avatar
RK
I completely agree with your last statement. Also agree that air can be charged by just starting and idling the engine. The point is that this way it is going to take longer, thats why they rev it.
I am sure someone on the forum owns a fleet of trucks / buses. Maybe they can have a chat with one of their drivers and clarify.
__________________
27th July
Old 2nd February 2006, 14:07   #29 (permalink)
DRC
DRC's Avatar
Anyone has fleet, I am sure he is going to get as many opinions as many drivers he has in his fleet
My personal experience, and no offence intended, all drivers I have talked to so far, have their own justification, which most of the times are too non technical...
Just a few I had ..
A tempo traveller can not have a Powersteering as it is a rear wheel drive..But a tata truck can have one though it is rear wheel drive because it as 4 tyres at the rear. A tempo tevellerr with PS will topple.
Sumos topple for no reason after 60, 80, 100km/h (depending on the driver)
Air breaks dont work in case of a puncture, as the tyre looses air. So they are good for heavy trucks only..
Powersteering is bad for Ghat roads, they take engine power while climbing up and loose control while climbing down
U must use high beam if any one comes in front of you (he says its a rule)
For a truck you should remove radiator cap when climbing uphill to keep the engine cool and keep adding water to the radiator. ( this one I heard during the delivery of a truck in Tata dealer ship, A driver convincing his owner, after the TATA engineer explained in length the importance of radiator cap.
I have many more..
__________________
_____________________
Stand on your head, upside down..
The world does not look any different, but you sure will look different!
DRC is offline   Reply With Quote
Old 2nd February 2006, 14:09   #30 (permalink)
DRC
DRC's Avatar
Why so ever, anyone revvs his what so ever engine, follow the owners' manual. Period.
__________________
Thread Tools
Tuning diesel engines sakharamcool Modifications & Accessories 2 24th August 2007 06:13
Precautions / Maintenance for Diesel Engines with Turbo adarsh76 Technical Stuff 18 14th March 2007 15:17
Diesel engines -- different types and good diesel vehicles FourXFour Technical Stuff 3 23rd September 2006 08:57
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
