Thread Tools
Old 6th May 2008, 11:32   #46 (permalink)
Infractions: 0/1 (4)
Originally Posted by DieselFan View Post
If you have not gone beyond 1500-1600 you have not used the turbo at all so there is no issue.
Correction: You have not used turbo BOOST, but the turbochager has been spinning away nonetheless! It's bearings do need their lubrication and cooling.
Old 6th May 2008, 13:41   #47 (permalink)
DieselFan's Avatar
Anup - Turbo will spin even when idling. the point I was making is that the bearing will not get hot. Else what is the difference between driving without turbo boost and idling?
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Old 6th May 2008, 13:51   #48 (permalink)
Agreed DieselFan. I wish you had said it in the first instance itself!
And car makers have to keep the instructions very simple, so that the afficionado and the average joe can both use the car with success!
Old 6th May 2008, 14:04   #49 (permalink)
greenhorn's Avatar
A bit offtopic, but why do buses/lorries idle in a rhythm, instead of constant revs
__________________
2007 Indica DLG
My next Truck will be a Safari!
greenhorn is online now   Reply With Quote
Old 6th May 2008, 14:19   #50 (permalink)
Something which I heard long back.
Never followed with my petrol car in India, but followed in US.
When we start the engine, the rpm is slightly higher than the idle rpm(for Swift D idle warm rpm is 800, while at start it touches 900+)
Allow it to come to warm idle rpm (800 in this case)
Is this true? Can that be a bench mark than 30 sec or 1 min idling?
I normally see that it takes more than 1 min for rpm to settle down.
__________________
Swift VDi - Apr 2008
Alto LXi - Jun 2004 - Apr 2008
sriturl is offline   Reply With Quote
Old 6th May 2008, 14:29   #51 (permalink)
svsantosh's Avatar
Lightbulb
Thats constant for them.
What I meant is for a human ear, 1000-1200RPM Idling of a car feels like a whine/whisper without a rhytm, But trucks (Indian) Redline at 2000-2500RPM. You can imagine the Idle Speed - 350-600MAX. (Do you know ships Engines Red Line at around 100-150RPM).
What you call a rhytm is a huge 6Cyl - 6-8Litre - DI Diesel Engine slowly clattering away at Idling speed. (Reason - Low Revs + HUGE FLYWHEEL = TORQUE TORQUE and More of It)
Ps - remember hearing the famous Indian Railways Diesel Loco's chugging away at platform's end in idling, what a sound to remember in our childhood. Check out the specs and you will know why that Giant;s idling is sweet music.
Engine: Alco 251-B, 16 cylinder, 2600hp (2430hp site rating) with Alco 710/720/?? turbocharger. 1000rpm max, 400rpm idle; 228mm x 266mm bore/stroke; compression ratio 12.5:1. Direct fuel injection, centrifugal pump cooling system (2457l/min @ 1000rpm), fan driven by eddy current clutch (86hp @ engine rpm 1000).
Source - [IRFCA] Indian Railways FAQ: Locomotives -- Specific classes : AC Electric
Hope that helps.
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 6th May 2008, 15:00   #52 (permalink)
Su-47's Avatar
Adding to the OT stuff: Do you by any chance know how much Torque it makes?
Quick calculation assuming a flat curve shows somewhere around 19K+ N-m. So next time someone says "My car pulls like a loco", we better take notice. Sorry about another post, the 20-min limit had expired :(
__________________
Never wrestle with a pig, for if you do, you will both get dirty, but the pig will enjoy it - Charlie Munger
Su-47 is offline   Reply With Quote
Old 6th May 2008, 15:34   #53 (permalink)
DieselFan's Avatar
Never Idle latest Gen Diesel engines. Engine do not warm up by idling.
Swift D should be driven at a low RPM (Below 2000) initially till the temp needle reaches the halfway mark and stabilizes after that increase the RPM beyond 2000.
__________________
Old 6th May 2008, 17:05   #54 (permalink)
Actually, the thread title is a bit misleading. Modern diesel engines are NOT revved up before being turned off; they are 'idled' (revved down, if you please) for a while before being switched off. This is done to allow some cooling-down period for the turbo.
Old 6th May 2008, 18:15   #55 (permalink)
Jomz's Avatar
They don't need to do the revvin because of this reason because, at stop when the air is fully discharged, there si some sort of a spring mechanism to lock the brakes.
they need to rev up at start so that to build air pressure against the spring thingy.
Originally Posted by Sideways View Post
To answer your question specifically - Most truck and buses have air brakes. This air is stored in a tank and needs to be charged and therefore these guys rev the engines before they stop and just after they start so that they have some kind of braking power. The rest of it is hogwash.
__________________
Loves Subarus and accords.... Till now!!!
Jomz is offline   Reply With Quote
Old 6th May 2008, 19:42   #56 (permalink)
Ignazio's Avatar
simply is a safety issue, big vehicles (bus, trucks) have a brakes system that work in negative way. You need air to unlock the brakes, if your air circuit has a leaking, your truck simply will stop once air is finished and compressor (driven by the engine) is not enough to keep air flow at the right pressure. When I was at National Service, we had a truck with a little leaking, my driver at start, had to revv a lot to get the pressure at the right level, to unlock hand brake and let us go. Many heavy vehicles also have pneumatic suspension and some have pneumatic controlled gear box. Fill in air reservoir (if you have a little leaking) I think is the only reason to revv the truck before stop, just to have top pressure in to reservoir and avoid wait too long at start...
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 6th May 2008, 21:49   #57 (permalink)
kuttapan's Avatar
AH, missed this thread...Ignazio has come up with what I wanted to say...Parking brakes on buses/trucks are always air to deactivate. Remember my Dad telling this long back, when I was a kid and used to quiz him.
The TATA(earlier Benz) buses, though had mechanical parking brakes for a long time, before air brakes became default.
kuttapan is offline   Reply With Quote
Old 7th May 2008, 00:53   #58 (permalink)
SirAlec's Avatar
they are revved, to fill the air tank, for vaccum assisted brakes. If you don't rev it while on the next start you may have to keep the engine running idle until BAR guage reaches 6 bar (about 87psi). you normally hear warning beep.
__________________
Living Life a quarter mile at a time...
Thread Tools
Tuning diesel engines sakharamcool Modifications & Accessories 2 24th August 2007 06:13
Precautions / Maintenance for Diesel Engines with Turbo adarsh76 Technical Stuff 18 14th March 2007 15:17
Diesel engines -- different types and good diesel vehicles FourXFour Technical Stuff 3 23rd September 2006 08:57
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
