Old 3rd June 2010, 21:07   #1
Question The heat is on, way too on! Car overheating at low RPM
greetings all!
i'm the proud owner of a 1996 mercedes E220 and more recently, a fabulous force gurkha!
curiously, i've been experiencing the same trouble with both vehicles--over-heating at low rpms, while idling and in traffic.
the benz went to benz and is being sorted out out after a 10 day diagnostic, while the gurkha is way too new for such trauma!
any advice and help would be highly appreciated!
regards all
sankidude
sankidude is offline   Reply With Quote
Old 4th June 2010, 14:46   #2
Rehaan's Avatar
Thanked: 22,606 Times
Is your parking space home to some hungry rats? They sometimes dine on wires, say, for the radiator fan etc.
Did you check if the radiator fan was coming on while the cars were overheating?
cya
R
PS - Welcome aboard. Do go through our rules, and please try to use proper capitalization too. Thanks.
Old 8th January 2012, 03:14   #3
Thanked: 701 Times
Default Ford ikon overheating?
My ford ikon 1.8 diesel, which have run over a lakh km, is showing signs of overheating.
From cold to normal temperature(which is just the quarter level in the temperature gauge, as identified in a lot of 1.8s), the needle movement is gradual.
I can hear the fan kick in just after it crosses the quarter mark, but then it stops within a 10-20 second period.
From this level, till it reaches half level mark, the fan doesn't come on; it is only when the needle crosses a tad above half mark, it comes on and off(the cycle).
This happens only in city/sub-urban traffic conditions; on a freeway/highway, the needle stays at the quarter mark(which is the normal position for all ikon 1.8Ds).
A local mechanic judged the issue to be a faulty temperature switch; i did replaced it; the issue still remains.
Even when the AC is switched on/off, there is no change of this behavior, and most of the times i dont use the AC at all.
Not that this is a very serious issue, but it is eating my mind for a while, because there is always a worry to keep an eye on the T needle.
I did flushed out the radiator as well as the cooling system and while doing so, the thermostat valve was replaced.
So to pose a query, if there is no fault on temperature switch, thermostat valve, radiator and the fan, where else lies the problem?
PS: does the ikon D fan has only 1 speed(that which creates a racket, lol)?
ramzsys is offline   Reply With Quote
Old 8th January 2012, 11:31   #4
VANOS's Avatar
Thanked: 20 Times
As far as i know the 1.8D, the normal operating temp is 80 - 90 degree C. That is around the mid of the gauge. And the fan runs on 2 speeds. As long as it does not go beyond the half way mark, it's o.k. It sometimes does in urban crawl. But gets back once the second speed kicks in.
VANOS is offline   Reply With Quote
Fiat too wants to develop a low cost car for India navdeep The Indian Car Scene 32 21st October 2015 09:44
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
