Old 4th June 2010, 13:59   #1
Thumbs down Strange Sound while switching The Car A/C
I am getting a strange sound while switching the car A/C on. Its like a puff or a hiss sound but loud, when the car A/C is switched on. The car is Maruti Ritz ZXI 2009, November built.
As per MASS technician, this sound comes in every car when the A/C is switched on after 1 day or so. But I get this everytime I switch the A/C on.
Has some one else experienced this in their cars ? Is this normal /
Any and all advise would be appreciated.
del.guy22 is offline   Reply With Quote
Old 4th June 2010, 14:05   #2
Hey,
Even i am getting the same hissing sound. Though my wagon r has done 32k.
I think the problem might be something related to gas leak.
Ill get it checked with MASS.
footloose15 is offline   Reply With Quote
Old 4th June 2010, 14:12   #3
ghpk's Avatar
Thanked: 105 Times
Have you tried looking inside bonnet, it can sound from Relay,
once you turn on the A.C. the relay clicks which then starts the compressor.
if you visited M.A.S.S. Have you checked it on other Ritz ?
Old 4th June 2010, 14:13   #4
Thanked: 44 Times
I feel this is normal. Happens in my Swift as well. I feel it has nothing to do with after what duration you switch it on.
hyper-VTEC is offline   Reply With Quote
Old 4th June 2010, 14:27   #5
Thanked: 454 Times
I have this loud sound in my A-Star everyday i turn on the AC for the first time. In my car the sound is a bit metallic and loud, but with the windows rolled up it does sound like a Hiss sometimes.
There is nothing to worry about i guess. But i wonder why the older cars doesn't have this.
Old 4th June 2010, 14:46   #6
grules's Avatar
I have this same sound in my Indica V2 too. At first i was so confused if it was from the speakers in the door, but later traced it to the AC vents. I especially hear a distinct hissing sound from my left AC vent when the blower is in full speed and reduces gradually when the speed setting is reduced.
I was told that this could be something stuck in the AC duct which could cause the whistling/AC sound. I learned to live with it now. (Noticed it in another Indica running as taxi too.)
grules is online now   Reply With Quote
Old 4th June 2010, 14:57   #7
Gilead's Avatar
I was told by M.A.S.S that the hissing sound from the AC is a sign of low gas. I noticed this sound after the car had done 35K kms. The AC was serviced and there has been so sign of the sound since then. This is on an M800. I don't think the hiss is 'normal'. There is no such sound in my Fiesta.
Gilead is offline   Reply With Quote
Old 4th June 2010, 15:17   #8
I also feel this is not normal. The sound is loud and looks like gas going into something when we switch on the AC. My friend has Ritz VXI and have not heard any such sound in his car. My car has done about 1400 kms.
Looking forward to take to Maruti sales and service, a company owned service station @ Naraina, Delhi.
Old 4th June 2010, 20:39   #9
Mine is a Ritz Feb 2010 done around 2K and I also get this sound from my car when I switch the AC on. Atleast to me it looks normal.
anupamsinha is offline   Reply With Quote
Old 11th June 2010, 18:53   #10
Thanked: 68 Times
Hissing is the sound gas makes when there is a void & it passes through it. Don't worry unless you experience significant cooling loss. Gas is low but not so as to warrant a top up.
Get condensor coils in the front cleaned with medium pressurized water(as high pressure will deform the fins) every season to ensure good cooling performance.
JustCause is offline   Reply With Quote
Old 11th June 2010, 21:33   #11
Thanked: 95 Times
I hear a clanging sound & a hiss when i start up my Swift (2006 model, done 44K kms)
Have never touched the AC for any issues. Have no problems with the cooling either.
I dont hear this sound with my other cars !
nirmaljusdoit is offline   Reply With Quote
Old 11th June 2010, 22:32   #12
vigsom's Avatar
Thanked: 151 Times
You may get the system examined,but I feel there's nothing abnormal
Old 16th June 2010, 21:14   #13
The car is just 6 months old, Are you sure the gas could be less ? If I need to get it filled, who pays for it ? I don't think the gas should be less in 6 months and the A/C has been used really less.
Old 16th June 2010, 22:03   #14
Thanked: 68 Times
My car too made hissing noise this summer, when it was just 9 months old.It is just like an air bubble forms in a water tube, it is no cause for worry. My cooling is the same as it was last season & if yours is too, no need for a refill.
Do get condensor coils cleaned every season.
Old 17th June 2010, 17:23   #15
I get this sound everytime I start the AC. If its an air bubble,shouln't this go after couple of uses ?
Strange sound from the rear of INNOVA navine Technical Stuff 3 26th November 2009 14:50
Strange sound from the Bonnet of Esteem esteemer Technical Stuff 10 9th July 2009 17:08
A strange sound while braking zaks Technical Stuff 2 11th February 2009 21:24
Strange sound from the AC blower amit_mechengg Technical Stuff 8 16th January 2008 18:29
strange fluttering sound in my baleno abhishek_rait Technical Stuff 15 29th June 2007 19:01
