Old 4th June 2010, 15:10   #1
sgiitk's Avatar
Thanked: 3,759 Times
Default What is a Wave Key?
Honda literature/booklet for the Civic mentions a Wave Key as standard. The manual makes no mention of it.
What is it? Is it actually there in the car? Please educate me on this.
Old 4th June 2010, 15:48   #2
vasoo's Avatar
Thanked: 207 Times
As per Honda website...
Engine Immobilizer
Complementing the keyless entry system is a standard engine-immobilizer system. A special electronically coded key (wave key) prevents the car from being started-even if a mechanical duplicate of the key is used. A transponder, built into the key, signals the immobilizer control unit that the key is genuine. If the car is hot-wired, or an unauthorized key is used, the engine will not start.
http://automobiles.honda.com/civic-s...re=immobilizer
vasoo is offline   Reply With Quote
Old 4th June 2010, 16:30   #3
Thanked: 23 Times
Per my understanding, this is a wave key
Now, the difference is the key grooves are not cut through the metal but only on the face of the key blade. This makes it tough to copy the key.
I cannot confirm that my assumption is right.
MrinalSinha is offline   Reply With Quote
Old 4th June 2010, 18:51   #4
Rehaan's Avatar
Thanked: 22,612 Times
Originally Posted by MrinalSinha View Post
Now, the difference is the key grooves are not cut through the metal but only on the face of the key blade...
Does indeed look like a wave on the surface of the ocean
Old 5th June 2010, 23:21   #5
sgiitk's Avatar
I guess both are correct, but immobilizer is common. So the latter may be the answer.
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
Bose Wave Music System - is it any good? ntomer Gadgets, Computers & Software 27 16th March 2007 16:29
converting Midi files to mp3,wave,wma viper Shifting gears 7 5th May 2006 02:31
