Old 21st August 2010, 16:08   #16
Rai
Default More details on the fix please
Originally Posted by cdmanju View Post
The issue was - there was no power supply from AC relay to AC system. He did something and got it fixed.
Hello cdmanju,
Can you please give more info/details on the fix done to your car. I have exactly same issue in my Fiat Petra 1.6 ELX.
Last three weeks, I am trying to get this issue fixed. Changed the Evaporator (of-course my Evaporator was fully clogged), Changed Expansion Valve and Changed Thermostat. (All repairs done by Tata/Fiat Dealer in Bangalore). Still the Problem exists.
AC works fine for first 20 Minutes, with very good Cooling, Afterwords it doesn't work.
Rai is offline   Reply With Quote
Old 21st August 2010, 16:31   #17
Rasputin's Avatar
Had the same problem in my father's Siena TD60. The problem was later traced to compressor getting heated up , which results in pressure build up in the system and subsequent cut off. Finally solved it by changing the Compressor ( which was procured by V-Cool Bangalore) . Costed me about 18K.
Rasputin is offline   Reply With Quote
Old 28th September 2010, 01:54   #18
Originally Posted by Rai View Post
Hello cdmanju,
Please little details of the issue, so that i can co-relate and guide you better.
cdmanju is offline   Reply With Quote
Need some guidance on the Calicut - Pune / Mumbai road arunkmar Route / Travel Queries 13 25th April 2012 07:45
Need some advice about my 10 yr old Fiat Siena chats Modifications & Accessories 2 13th December 2010 16:05
Siena brake problem - need advice fast lane Technical Stuff 13 12th November 2010 10:16
Fiat Uno With a Siena / Siena Weekend 1.6 Engine moralfibre Modifications & Accessories 9 1st August 2008 14:20
