Thread Tools
Old 28th October 2005, 17:19   #1 (permalink)
ramkya1's Avatar
Default IFTEX System G - Cleans the Jets?
Hai BHPns,
The manufacturer of system G , added to petrol, recommends 1 ml for ltr for optimum benefit. My dealer told me to use 2 squeezes, 20 ml for about 40-45 ltrs which means its about 0.5 ml per ltr. My questions to the techies are:
1. Does this thing really clean the jets, its adds about Rs.1/- per ltr on recommended use.
2. What is the correct ratio, 1ml / ltr or 0.5 ml / ltr?
3. Is it available in all petrol bunks, Im going off to a long, long trip.
Thanks for all help and information.
-- AMR
ramkya1 is online now   Reply With Quote
Old 4th November 2005, 09:38   #2 (permalink)
I think it does, atleast to some extent. No harm in using it, it can only do good.
I have heard more on the lines of 1 ml/ltr
On all decent pumps. Usually on all good HP and BP outlets atleast.
Well, if you are going on a long trip you might consider going to the service station(MASS or similar) and get the injectors cleaned.
Maruti Service centers generally charge INR 400 and they clean the injectors thoroughly.
If you get this done after a long time - you will easily notice the increase in performance and FE.
imjimmy is offline   Reply With Quote
Old 4th November 2005, 19:55   #3 (permalink)
hello ramkya....i haven used iftex but i have been told that u are to use 0.5ml for every litre for the first 1000kms and then raise it to 1ml to every litre...
inmate is offline   Reply With Quote
Old 4th November 2005, 22:21   #4 (permalink)
Kaizer Sozay's Avatar
i have used iftex, i put 2 cap fulls in a full tank. 30 liters, but there are a lot more additives available. I have seen STP , Bardhal & some other brands being sold.
If one normally does fill speed or power what extra benefit do these additives give?
Kaizer Sozay is offline   Reply With Quote
Old 6th November 2005, 17:22   #5 (permalink)
passionpurple's Avatar
Default what do you recommend??????
there are lots ot brands of feul additives.. can the bhp'ns please tell about:
1) which brands really cleans well the feul system and injectors?
2)how well does fluid cleaners compare to a machine cleaning done at the service station?
3) how often should the machine cleaning be done at the service station?
please help......
passionpurple is offline   Reply With Quote
Thread Tools
System G (IFTEX): yes or no???? Jaggu Technical Stuff 79 10th October 2008 11:47
System Purge - Iftex toiingg Technical Stuff 12 19th August 2008 11:25
Honda Jets to the Future Rekha The International Automotive Scene 10 17th January 2008 08:56
Who cleans your car(s) ? theMAG Shifting gears 31 8th December 2006 18:36
Solex fiat jets topend_hooligan Modifications & Accessories 1 1st February 2006 08:49
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
