Old 7th June 2013, 00:25   #256
ilangop's Avatar
Thanked: 587 Times
Default Re: TATA nano - List of ALL issues
Originally Posted by rock18 View Post
Bought a new nano 2012 model this week for my dad.I observed the following complaints.
1.Car struggles to move with AC and 2ppl on board in 3rd and 4th gear.I don't want to press the accelerator hard as its still new and needs a proper run-in.Is it the same case with other nano's also?
2.In a hot day,Ac does not cool enough,it throws chill air and then all of a sudden no cooling for sometime. I am not sure if it has something to do with the compressor cut-off when the throttle is pressed fully.
3.Have done 220kms so far,already faced starting problem twice. last time,i had to crank 3 times and it got started 4th time.
From whatever reviews,i have seen, Nano's pick up and A/C is very good.
I find this a bit contradictory.
Please suggest if something is wrong with my car.
Congrats on your new buy. I believe, there is no thermostat setting which you can do manually. All you have to control is the blower speed and turn ON the compressor. As a result the logic to cut-in & cut-off the compressor is solely dependent on the blower speed positions and the actual temperature inside the cabin.
Try running the blower set in position 2, I hope the cabin wont be deprived of cool air.
In any modern car, the Engine management system will cut-off the AC compressor while the drive floors the pedal suddenly. This is not just specific to Nano alone.
ilangop is offline   (1) Thanks Reply With Quote
Old 7th June 2013, 12:06   #257
Thanked: 140 Times
My Nano is having an odd behaviour of power loss at times in the 3rd gear. It kind of feels like the clutch is slipping or as if the petrol flow got cut off when driving in 3rd gear. This happens only occasionaly. The car has run for about 800km so far. There are no such issues in any other gear. Any insights into the possible causes ? The first service is due in 1500km, but I want to get feedback from fellow Bhp-ians before I meet the SA.
kutts is offline   Reply With Quote
Old 7th June 2013, 13:03   #258
Thanked: 12 Times
Originally Posted by SirAlec View Post
mine was cranking, but not starting, how about yours. ?
also there was a starter motor and wiring harness recall on nano. Did your friend attend that workshop.
In my case, car was silent while turning the key in the the ignition. It couldn't be battery issue since all the electrical things were working fine. Could it be because of insufficient fuel in the tank?
I got the fuel tank full yesterday and it seems to be starting up fine since then.
Btw, I did ask my relative about the workshop and they have no idea about that. What it was all about?
HR-06 is offline   Reply With Quote
Old 7th June 2013, 16:06   #259
Thanked: 660 Times
if it was silent then definitely some loose connection.
there was a major recall of all nanos. Mine is a new bs4 version, it was even called.
Old 10th June 2013, 20:31   #260
Why dont't you register a formal complaint on tata motors/nano website and get your car checked.
Let me point out a big difference in visiting a Tata Motors service center and registering a complaint. When you do the latter the company takes note of the complaint and it gets stored in their databased + they usually follow up with you on your satisfaction with their resolution.
Trust me Tata guys have done a great job with all such complaints. I own a Vista and my cousin owns a Nano and we've noted the difference.
For all you BHPians, here's the link and call center no: 1800 209 7979
Link: www.customercare.tatamotors.com/Complaint.aspx
bigautobuff is offline   (2) Thanks Reply With Quote
Old 10th June 2013, 20:55   #261
mercedised's Avatar
Thanked: 174 Times
The speed of blower of my Nano, sometimes suddenly reduces. For e.g. I am running blower on speed 3 but sometimes the air flow is like the blower is running on 1st speed (when the knob is still at 3rd speed) it continues like this for indefinite time and the speed returns to normal when the car is switched off for some half-hour, this problem happens on long drives. I think that the blower is getting heated-up.
Old 10th June 2013, 22:55   #262
Thanked: 1,428 Times
Originally Posted by canonball View Post
AC cooling cuts out/does not cool (unsure if compressor is on/off) for several minutes whilst driving and the cabin becomes somewhat hot. This has happened 4 times in the 500km or so I have driven it so far.
Funny. I have yet to experience this 'cut-off' feature, after clocking 16k kms. Is this some new feature introduced in the latest Nano? Mine is a 2012 LX model.
Someone said since my car is new perhaps brake pads/shoes need to bed?
If the vibrations occur only while braking, it might well be the cause. Still, it would be good to get the front brakes checked and cleaned up if needed.
Fuel tank reading in dash seems to show one bar less to full despite filling tank up! This started happening in recent full tank ups and not initially.
I get this all the time. Nothing to worry. Usually when the level indicator wants to turn one notch lower, from four bars to three bars, it keeps playing between three and four for awhile before settling down to three. I see it all the time. Initially I was worried, now I just live with it.[/quote]
As per my rough calculation car is returning an average of 12.5 kmpl. Read somewhere that this could be the case until the 1st 1000kmpl. I have covered 500 km so far
That seems normal. My FE till the first 1000 was around the same. It shot up to about 16 post the first service, and now it's near-20 most of the times.
I hope you aren't trying this after riding over a speedbreaker? What are the speeds you are talking about? It's rather difficult to try and accelerate in the third and fourth gear and that too wthout pedal assistance. I suggest shift down a gear or two and accelerate again back to third-gear speeds, instead of trying to coax the engine to remain in 3rd.
Did you let the engine cool down completely before switching off? Before switching off, always listen for the whine of the radiator fan. It also shows by way of slightly increased vibrations. Once the fan dies out, only then switch off the engine. If you switched off the engine before the fan had died out, you will face starting problems in your next crank. This is a problem with most cars, not just with the Nano.
honeybee is online now   (2) Thanks Reply With Quote
Old 11th June 2013, 11:39   #263
nijelj's Avatar
Thanked: 393 Times
I noted this behaviour on two very hot days. Once in Bangalore and once in Kerala. I also thought that the blower/cooler reached its limits.But then it happened again on a rainy night.I turned the thermostat to hot air and ran for 2 minutes.The blower air flow increased significantly after that.I think it is because of the icing that happens with humid air.
nijelj is online now   (1) Thanks Reply With Quote
Old 11th June 2013, 12:15   #264
nijelj's Avatar
Thanked: 393 Times
I faced this problem too and I think this is linked to the electricals also( faulty or inconsistent Fuel pump relay?).
Starter motor Relay?The day after this, I had stopped at an ATM and on returning to the car, I was not able to crank the car (starter was not activating). I had to wait for 5 min and then started again.Again this happened after a nandi hill run.I noticed that this happens only after an extended (5 hrs) slow speed traffic / uphill drive with AC on full time.
Wiper motor relay? : During some night light rain driving,I was driving with the headlights on and flicked the 'on demand' wash and wipe.The wiper refused to budge.I switched the headlights off/on and then it started working.
In all these cases,I am doubting a sticky or weak relay contact or a momentarily weakened battery.
I reported all this to Concorde,dairy circle and lodged a complaint on the Nano website asking them to think about better quality relays and/or upgrading the battery.They said they checked the alternator and starter motor and found no problems. It happened once after that too.
So now I dont switch off at Traffic lights :-(
Other Tbhp nano owners have also faced this problem (for eg.HR06),
nijelj is online now   Reply With Quote
Old 11th June 2013, 21:45   #265
rock18's Avatar
Thanked: 54 Times
Thanks for replying.Yes i tried running it both in 1 and 2 but never in 3.
I will check this in the first service.
Thanks for replying.Sure already i am getting lot of calls about feedback from tata motors.
No.Infact i need to go to gear 1 after riding over a speed breaker.This car has some weird gear ratios.3rd gear picks up speed only after 40-50kmph.I am still getting used to this.
Thanks for replying.I never know about this stuff.I will keep this in mind.
This problem did not come afterwards..car has touched 500kms so far.
rock18 is offline   Reply With Quote
Old 26th June 2013, 13:08   #266
saket77's Avatar
Thanked: 4,846 Times
And to all Nano lovers, something to admire:
http://timesofindia.indiatimes.com/i...w/20775716.cms
A Nano driven across the country covering over 10K kms in 10 days = Guinness World Records
Saket
saket77 is offline   Reply With Quote
Old 19th July 2013, 15:14   #267
Thanked: 289 Times
Hello all,
A week ago I gave my car to Balaji Garage for replacing all 4 shock absorbers since the original ones had become rock hard
and the ride harshness was that of a bullock cart! Luckily this was claimed under warranty.( not an easy task, long story behind it)
Since the oil change was also due, I asked for that too.
I picked up the car the same day, and on my way home saw that the "high beam" dipper was not working, nor was the hazard
warning switch. The subsequent day, my check engine light came on while driving to the park and in a few minutes, the
coolant warning and the loud beeping started too. Stopped the car and checked coolant level. Was at a perfect level. Left
the car alone for an hour and drove back home. This time, the check engine light had gone. Went to Balaji again, but had to
wait for 20 minutes till the guy with the scanning tool came out. Also the manager says to me, that connecting the laptop
to the car will cost me Rs.250 and that is payable by me and not covered under warranty. Anyway, the mechanic comes out
with the smaller scanning tool and just my luck, the warning was gone. Mechanic says nothing can be done now.
Same warning next day just when I reached my workplace. Decided to take it to Balaji again. Barely drove a couple of kms
and the engine started juddering. Quickly diverted to Pandit Auto's huge workshop in Bhosari. Last 2 kms were a nightmare. Had to do scary stuff that cannot be repeated on this safety-loving forum :-). For the record, I do my own stunts.
Anyway, the Service Advisor says to me that they can extract the historical data from the ECU and it is not a problem if
the Warning light disappears by the time the mechanic touches the car. Bad news, here they charge much more than Balaji for
the laptop.
They kept the car for 2 days, and concluded that the car needs a new thermostat cover ( SInce they noticed a coolant leak). Both covered under warranty, yet I had to shell out Rs.449 for the laptop diagnosis.
I was there when the laptop was connected to the Nano. It seemed like a very easy to use software with multiple tabs. Each
tab was for a different part of the engine. In my case, the software did not tell us anything that we didn't already know.
The cryptic message was "Check cooling system"or something like that.
Heavy rain in Pune last 2 days. On my drive back home, I drove slowly and carefully through a 6"-8" ( at least) deep pool
of accumulated rain water. After this pool the road was quite empty so increased speed to 40 kmph. Then I remembered my
Enfield's behaviour after pressure washing. So immediately checked my Nano's brakes. What brakes? :-). The drum brakes were
quite useless thanks to the dunking. Pumped the brakes for a bit, but improvement was very gradual. Lesson learnt.
A day of driving, and the AC stopped cooling. Drove back to Pandit who fixed it in 5 mins. They said that it was a blown fuse.
john doe is offline   Reply With Quote
Old 23rd July 2013, 23:11   #268
Hello,
this thread is really an eye opener, thanks a lot for all your posts. Already learnt a lot.
I got a second hand Nano LX 2011 (Jan) from a Tata showroom last week and yesterday my speedo was not working anymore. Since there is heavy rain at the moment, I didn't find the right time and place to check where the problem might be.
Does anyone know, how the speedo is connected and where the cable runs through? I guess, it is a mechanical one, right? I could not see anything under the bonnet.
The car is driving very nicely otherwise, only that my left front tyre is half blank. The speedo is showing only 7k, little strange. I read about the alignment problem and the suspension issue and will try to analyse this problem next time in the garage.
I read the Nano manual, but nothing about the speedo.
After reading almost the whole thread, I have the feeling, more than one of you has been under the car with eagle eyes. ;-)
Any help is appreciated
Raju
RajuPrabat is offline   Reply With Quote
Old 24th July 2013, 00:45   #269
Thanked: 289 Times
For a front tyre to go bald within 7 K is very unlikely. Probably the half bald pattern indicates an alignment issue. Should be easy to check for Rs.250/-
Worrisome is how the speedo stopped working. Connected to the odometer, isn't it? So is the 7K figure tampered with?
Can you please share with us what you paid for the LX, so that we all know what our cars are worth in the 2nd hand market?
Old 24th July 2013, 10:40   #270
saket77's Avatar
Not really want to be a party spoiler for you, but I think what John suspects is likely to be true. Though not impossible, but still 7K is too low reading for a used car.
You can use this link to check: http://www.tatamotorsassured.com/ind...l&view=tmasell
Also, the balding of tyres can be an alignment issue, if the tyre was not specifically changed to an older one before the seller handed over the car to you. Suggest you to get the alignment & balancing checked.
Speedometer is most likely to be a bad speedo cable or one that has come out.
saket77 is offline   (1) Thanks Reply With Quote
Tata Nano - Official Accessories List! abs The Indian Car Scene 47 20th November 2016 21:23
A Nano trip on a Nano budget...in a Tata Nano novice_alto Travelogues 11 28th September 2014 15:19
Tata Nano - Technical Specifications & Feature List Stratos Technical Stuff 1 24th June 2011 19:37
The Tata Nano Gamble - how many Nano Tatas will have to sell agentsmith2 The Indian Car Scene 41 28th October 2009 13:40
