Old 20th August 2015, 00:00   #466
Thanked: 1,429 Times
Pankaj, clutch replacement at 24k kms seems a little premature. Replacing the cable should be enough to get rid of the hard 'clutch'. I am on my original clutch after 52k kms, and I am no gentle driver.
Old 20th August 2015, 13:17   #467
Thanked: 42 Times
Smile Re: TATA nano - List of ALL issues
@honeybee, yes this is what I thought too that 24k kms is too less for clutch to be replaced. Changed just the clutch cable at first, however it did not solve the 'hard' clutch problem for some reason. So, SA @TASS advised to replace with new 'kit'.
I was used to the hard clutch all this while. However, my wife has started learning on Nano recently, and she was having a tough time in disengaging the clutch. Hence, went ahead and replaced, with no second thoughts .
pankajn1702 is offline   Reply With Quote
Old 23rd August 2015, 07:37   #468
zaheer5776's Avatar
Thanked: 43 Times
Default Re: TATA nano - List of ALL issues
1. From all the posts regarding hard clutch problems I have concluded that I should wait more before I decide to change the clutch assembly. I have also noticed that sometimes the Clutch becomes normal and sometime it becomes harder. Since the car is giving mileage of more than 21 kmpl consistently I feel everything is working fine.
2. Now friends, in my area I have found a Nano which had a front crash and got scrapped The car's interiors are in perfect conditions including the side mirror. Its parts are available with the scrap dealer. I went there to check if I can get something for my Nano as the Year of make and model is same that of my Nano ( lx 2011) Now my question is shall I buy the clutch parts too for my future use or which part I may need to keep in backup as its rare to get. I am thinking to buy a rim as it may get bent sometime. Guys please suggest!
zaheer5776 is offline   Reply With Quote
Old 23rd August 2015, 11:12   #469
Tanmay K's Avatar
Thanked: 182 Times
I have never run into a situation when I couldn't find a specific part anywhere for the Nano. Most of the things are available with TASS or 99rpm or your good old local aftermarket shops.
Having said that, I think you should try to see if you need some part for your car that is available only as a subpart of a larger assembly. One example that comes to mind is the lid/cover of the 12V outlet; if you somehow manage to lose the lid, you would have to replace the entire unit.
Tanmay K is offline   Reply With Quote
Old 23rd August 2015, 12:35   #470
mail2sekh's Avatar
Thanked: 52 Times
A few other examples which I faced :
1) The knob for switching between inside/outside air conditioning.
2) The flaps of the air conditioning vents.
Both of which broke off in mine. They said that I have to replace the entire AC unit to fix this.
So I lived with external air circulation and individually adjustable flaps for the last two years till I got the new GenX. Now it is freezing inside with fan at 1 and AC not even at the coldest position. Seriously the air cooling is too much in the nano.
3) Central locking also failed for one of the rear door locks. Again they said the entire locking system has to be replaced. Since I mostly travel solo, it was not an issue.
mail2sekh is offline   Reply With Quote
Old 23rd August 2015, 14:42   #471
Tanmay K's Avatar
Thanked: 182 Times
This rang a bell. Was it not covered under warranty? My rear left central lock works around 40% of the times at the moment and I can definitely see it failing sometime in the future. I have also read about this issue earlier in this thread here (TATA nano - List of ALL issues), as well as met another Nano owner at the TASS in Gurgaon this March with the same concern.
Originally Posted by turbodude View Post
First one is rear left side door lock does not open with the central lock. It gets locked properly but I have to lift it up manually to open the door. It was solved by Balaji Cars successfully. This month its there again.
I wonder if this is a widespread problem across many Nanos.
Old 23rd August 2015, 21:19   #472
turbodude's Avatar
Thanked: 126 Times
I face this problem during rainy season only. All other time it works perfectly. The rear left door lock was replaced twice, still same problem persists.
We are treating it as child lock now , unique feature of Nano during rains
turbodude is offline   Reply With Quote
Old 24th August 2015, 00:15   #473
I face this issue in my Nano too. I have a 2012 LX model, and the rear door locks don't unlock when the driver side door is unlocked. This happens only in monsoons
Old 24th August 2015, 20:32   #474
Thanked: 42 Times
I face the same problem during monsoon. I take it to the local mechanic, who doesn't charge for this.
This year, passenger front door wasn't opening during monsoon. It needed some grease, and got that fixed too from the same mechanic. Paid him Rs 100/- as can't expect him to do everything for free
pankajn1702 is offline   (1) Thanks Reply With Quote
Old 7th September 2015, 08:48   #475
turbodude's Avatar
Thanked: 126 Times
I faced a weird problem yesterday. I have 12V socket fitted in the nano. I was using it yesterday and while pulling out the charger it just dismantled. I went to my electrician friend and got it reconnected.
But there is no supply to the wires now. He checked the fuse (CIGAR 10A written on FUSE MAP sticker below steering, 2nd right from centre). Fuse is OK but there is no supply. He tried his best and in the end just made sure that no wires are shorted.
We concluded that I have to show this to service centre now as they were the one who originally fitted it. I want a piece of advice from fellow bhpians, can I take this to some car decor shop as they can also fix 12V socket issues or go to service centre as I suspect some electrical issues behind this.
If some bhpian is there in or around Kalyan West, can you help me out please. I need this 12V socket activated as I use it to charge my devices frequently.
Old 11th September 2015, 13:10   #476
Tanmay K's Avatar
Thanked: 182 Times
Hi guys
There is a repetitive problem that keeps cropping up again and again in my 2014 Nano. The bolts that connect the silencer to the gearbox housing keep coming off. I have gone to the TASS to get it fixed thrice already and each time they have installed new bolts (for Rs 300).
Yesterday after my 30k service one of these bolts came off again (and the other one became loose) and I went to Dhingra motors in Gurgaon to get it looked at. Unfortunately the SA who usually oversees my car was on a weekly off so the issue could not be resolved as I would go there another time.
In the meantime, anyone has a clue why these bolts keep coming off? Is there a way to permanently fix these bolts in their place?
As a result of the loose bolts, the silencer of the car becomes very noisy.
Here is a photo I took today. Notice the missing bolt and the loose bolt below it.
Tanmay K is offline   (1) Thanks Reply With Quote
Old 13th September 2015, 17:53   #477
turbodude's Avatar
Thanked: 126 Times
Update: I got our nano serviced from Concorde motors, Baner on 12th September. Service quality is good. Unfortunately they also could not fix this issue, the socket was not operational when I received the car in evening.
Got it fixed the next day from a car decor shop opposite darshan hall, chinchwad city. Reason was a blown fuse. Called up Concorde Motors and told them it has been fixed. Service adviser is still suspicious hence agreed to send someone to verify.
Still unclear what could have caused the issue. If someone can put focus I will be delighted. As of now 12V socket is operational .
Old 21st September 2015, 18:24   #478
mercedised's Avatar
Thanked: 174 Times
I am facing a strange issue from past one month, the problem has gotten worse with time :
Initially, when I slotted in first or reverse gear and by mistake used to leave clutch suddenly, there was a loud thud noise from engine, it was similar to the noise which comes when the car has a under body hit. The problem has grown with time, now the engine is vibrating more than before and there is loud noise (thus) when I leave the clutch (normally, not suddenly as I said before).
Now, at the last service the TASC guys told me that engine mounting A and C have gone bad, I in suspicion told them to leave it as it is. Could the issue be due to mountings?
mercedised is online now   Reply With Quote
Old 21st September 2015, 19:06   #479
pugram's Avatar
Thanked: 36 Times
I think the accidental clutch release has taken its toll. Please do the needful, as suggested by the service centre ASAP.
pugram is offline   (1) Thanks Reply With Quote
Old 21st September 2015, 20:04   #480
Tanmay K's Avatar
Thanked: 182 Times
It seems so. Take a quick look at this discussion: http://forums.mg-rover.org/archive/i.../t-200880.html
Tata Nano - Official Accessories List! abs The Indian Car Scene 47 20th November 2016 21:23
A Nano trip on a Nano budget...in a Tata Nano novice_alto Travelogues 11 28th September 2014 15:19
Tata Nano - Technical Specifications & Feature List Stratos Technical Stuff 1 24th June 2011 19:37
The Tata Nano Gamble - how many Nano Tatas will have to sell agentsmith2 The Indian Car Scene 41 28th October 2009 13:40
