Old 15th July 2010, 12:48   #16
rajismine's Avatar
Thanked: 252 Times
man...its almost 4 yrs I have my safari and I still dont pay anything for any part...how can you even listen when they ask 6K for any part....shout at them at the peak tone and they will listen..parallelly tell them u are escalating and will let Tata resolve...they will fix your issue in 5 mins :-)
rajismine is offline   Reply With Quote
Old 18th July 2010, 17:59   #17
Originally Posted by dadu View Post
As I predicted, the seal is the culprit here and if under warranty they will replace the whole pump under warranty. Ask them to avail warranty as this was supposed to be changed in the retrofitments and is a known faulty part.
Thanks all for support and info.. spoke to their seniors and got it replaced under warranty..had to pay only for the coolent..
sundeepg71 is offline   Reply With Quote
Old 28th July 2010, 14:25   #18
After all this rectification, this saturday to my anguish realized that a huge pool of coolant had accumulated below the hood and Coolant was dripping crazy.
Vehicle again landed up in Concorde, this time there was a leakage from the radiator itself.
Thanks to extended warranty entire radiator assembly was replaced at no cost.
Hope this should be the end of the coolant saga.
Old 28th July 2010, 15:57   #19
Thanked: 244 Times
Hopefully.,in opening up the faulty pump they damaged the Radiator as the position of the pump is not very convenient and lots need to be disbanded.
Old 2nd August 2010, 15:51   #20
There is a possibility as what you said..vehicle is more than 2 yrs old and suddenly how can radiator develop the leak ; when till this time there was no problem at all...when i saw the damaged one what was told to me was the welding has gone off ..seems quite unrealistic..
Old 20th March 2012, 18:05   #21
Default coolant leak - tata safari dicor 2.2 VTT
Hi All,
My Safari Dicor has been having coolant leakage issues and were being fixed in Concorde motors - Ambattur Chennai... Today again I discovered a leakage but very sceptical in taking it to Ambattur as it takes hell lot of time for fixing even minor issues.. Can someone suggest where I should get my vehicle checked near Annanagar area so that it is fixed once and for all.
Thanks,
Sundeep
Chennai
Old 20th March 2012, 18:35   #22
Thanked: 169 Times
Infractions: 0/1 (5)
Default Re: coolant leak - tata safari dicor 2.2 VTT
Hi All,
Thanks,
Sundeep
Chennai
Hi Sundeepg,
even the same happened in my vehicle, but when we checked it, it got the engine body leakage which was very minor asked them to any way replace the part as the part was not available i had to wait for a week and finally got it replaced.
whats the problem with your one. and how old is your safari.
SPEEDY_RACER is offline   Reply With Quote
Old 20th March 2012, 18:45   #23
Originally Posted by SPEEDY_RACER View Post
Hi Sundeepg,
Hi , Its a 2008 June Dicor 2.2 VTT , 4 X 4 .. The leakage is quite visible near the front right tyre ..its a greenish fluid ( a bit confused as it gives oily feeling when rubbed on the fingers..)
Old 20th March 2012, 22:09   #24
Catalyst_delhi's Avatar
Thanked: 148 Times
Coolant do feel oily due to presence of silicates. Looks like you have other problems as well in your cooling circuit.
Usually Radiators burst if the Pump is not working , blockage in radiator , thermostat opening late. So
Do a flush
Replace Thermostat
Replace radiator
Also replace Cap
Also check if the coolant concentration is 50/50 for perfect cooling and corrosion protection
Catalyst_delhi is offline   (1) Thanks Reply With Quote
800 Consuming coolant humyum Technical Stuff 28 5th March 2015 15:45
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
Water or Coolant? Team123 Technical Stuff 21 24th April 2006 08:57
coolant guzzling Esteem chandan Technical Stuff 10 21st July 2005 12:28
