Old 28th June 2010, 16:37   #31
planet_rocker's Avatar
Thanked: 368 Times
@ Jacs - even i was surprised to see water inside the cluster. it was opened last at FASS about a year back and i guess the glass sealant was not used properly / evenly.
i will have to buy a new head lamp sooner or later. the amount of water inside was scary and it was dirty water.
anyways will keep you guys updated.
planet_rocker is offline   Reply With Quote
Old 29th June 2010, 10:22   #32
Thanked: 368 Times
Kolkata received 75.6mm rainfall yesterday. Today the headlights look like:
the cluster was dry - will keep a watch on water leaking inside.
Next - getting rid of moisture from headlights.
Drive safe and take care.
Old 29th June 2010, 22:58   #33
Thanked: 70 Times
Hi Planet_Rocker
Indeed a very useful post.
Since I am not good at opening the cleaning the headlights I am still waiting to find some good guy who can do the complete operation. Till then I feel its safer not to do it rather then getting it done from someone who is not good at his work
Moreover with the headlights of my car moisture starts escaping once its dry for a day and when the headlights are switched on, its completly gone. And its also clean from inside (not muddy)
rikhav is offline   Reply With Quote
Old 30th June 2010, 10:55   #34
Thanked: 368 Times
Still dry from inside except the small amount of vapor inside the glass. you can compare with the pics in the previous post.
Sealing the top edge of the glass from outside (where the glass sticks to the plastic body) with fevicol / sealant should help.
@ Rikhav - it is very easy to open the back cover - similar to opening the back cover of a wall clock when replacing battery.
Old 20th July 2010, 18:48   #35
Thanked: 111 Times
Rikhav, what's the news on your Palio's headlamps? I got the headlamps on my Palio changed since I was travelling to Goa. Had to make do with non-motorized units since you don't get the motorized units anywhere. Cost me Rs.5100 including octroi etc etc. The lights are back to their original state, amazing spread & throw.
mb_jg is offline   Reply With Quote
Old 21st July 2010, 08:18   #36
Thanked: 70 Times
Still the same :(
Even I was thinking of replacing them in the next service. Are the prces from a TASS?
Kava had quoted a price of 2200 per headlight but did not have in stock. I wont mind paying a little extra if its an original part
Old 21st July 2010, 12:03   #37
Thanked: 111 Times
Originally Posted by rikhav View Post
Still the same :(
I got the original part alright, although it's not motorized, not that I needed it or ever used it. I can get you the set if you want. My cousin has a workshop in Kolhapur & he gets these parts from Mumbai, he can have them delivered directly to your place. I paid Rs.5100 which included octroi & something else. Will post pics over the weekend, I can't stop staring at them
Old 16th March 2015, 19:30   #38
Thanked: 70 Times
Default Fiat Petra Wiper Issues (intermediate Speed Not Working)
The wipers works fine in 1st, 2nd and 3rd speed but no movement when kept on intermediate
Is this a wiper motor issue, or there is some secondary component connected to wiper motor which governs the speed?
If yes, what is it called
Or its an issue with combination switch by which we control the wipers
Thanks in advance
Old 16th March 2015, 19:37   #39
SunnyBoi's Avatar
Thanked: 2,832 Times
Default Re: Fiat Petra Wiper Issues (intermediate Speed Not Working)
There is a white box with contacts, which tells the wiper when and how fast to run next to the wiper motor. That must have gone bad on your car, or it might be the combination switch with the intermediate switch not functioning.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 16th March 2015, 19:44   #40
Thanked: 70 Times
Thanks sunny
Any suggestions how i get to know which part is actually gone bad?
Any way i can check the white box?
Old 17th March 2015, 01:00   #41
rajeev k's Avatar
Thanked: 1,750 Times
Definitely,the wiper motor is not faulty.
In all probability, the combination switch is the culprit. Get it inspected.
rajeev k is offline   (1) Thanks Reply With Quote
Petra engine issues veegeerocks Technical Stuff 24 8th November 2009 11:27
Fiat Petra - Issues and Advice Needed shivag Technical Stuff 0 2nd August 2009 00:12
FIAT PETRA Power Steering problem and FIAT India's responsiveness! rishi_kapoor Long-Term Ownership Reviews 13 13th June 2009 09:09
Skoda Fabia/ Fiat Petra Beetle The Indian Car Scene 21 22nd June 2004 23:22
Fiat Petra sriban The Indian Car Scene 16 20th May 2004 19:14
