Old 21st June 2010, 09:50   #1
sureshshanmugam's Avatar
Default Fuel Injector
I am trying to understand a few things on fuel injector. Would be great if some mate can throw some light on the felow questions.
1. What is a Fuel Injector, how is it different from the operations of a carbeurator?
2. How often do we need to clean the fuel injector?
3. What is the procedure to clean an injecotr?
4. Are there any injector cleaning liquids that will do this job?
Thanks in advance.
sureshshanmugam is offline   Reply With Quote
Old 21st June 2010, 12:16   #2
sgiitk's Avatar
Thanked: 3,883 Times
I am talking purely in the context of a petrol engine. In a carb air as it goes in sucks in petrol. In an injector air control is different, and the petrol is injected (controlled by the ECU) in the manifold in the middle (Single point FI, now obsolete), just outside the inlet valve (MPFI - the most common), or directly in the cylinder (Direct FI). The control on the fuel is far more precise resulting in more power, better economy and lower emissions.
Depends. You may need to do so may be once a year or two in our conditions. If you use 'bad' fuel then you may need it more often.
Essentially force a solvent through the injector nozzle. This is what the cleaning machines do.
There are fuel additives which help degunk the injector system. They work only in very low levels of contamination.
Old 21st June 2010, 12:27   #3
Thanked: 245 Times
Thanks in advance.
Injectors can be of many types but their working meachnism is the same, see picture below. In a Carburetor fuel delivery is not controlled its forced using a fuel pump and mixed with air for the engine to burn.
In an injector the delivery of fuel can be controlled using the pintle inside it. If required I can post a sectional diagram for better understanding.
Size:  12.4 KBName:  2500km cleaned.jpg
Deposits at 2500 KM and then cleaned injector
Deposits that form on the injector nozzle can cause incorrect spray and atomization, but I would say you do not need to clean it regularly unless you have some problem symptoms or loss of fuel efficiency. As you see deposits start forming as we run the engine.
Again injectors can be cleaned manually by removing and putting them through cleaner machines using special liquid or by using fuel additives or by ultrasonic cleaning. Fuel additives being the easiest but not the most effective way.
I would say, always try mild additives before moving onto strong ones, SystemD/ G works good with most of us, otherwise move on to BG products, they are good.
Old 21st June 2010, 13:49   #4
dhanushs's Avatar
Thanked: 4,504 Times
You might wanna check out this link. Carburetor vs Fuel Injection
A simple yet detailed/useful explanation about how a carb differs from FI.
I guess modern day engines with fuel injectors are quite efficient from keeping away dirt from the injectors(I think fuel adulteration has decreased) and you will have to manually clean them only when necessary. ie when your car starts showing symptoms of power loss etc.. Otherwise using a good fuel additive should do the job.
This link may help.
Troubleshooting & Cleaning Dirty Fuel Injections
Old 21st June 2010, 14:05   #5
pranavt's Avatar
Thanked: 274 Times
Does anyone in India have proper machines to do flowtesting and cleaning of injectors? Wish to flowtest my injectors before putting them in my car.
Old 21st June 2010, 15:19   #6
sgiitk's Avatar
I think most of the better garages have them. Check for volume in a certain number of cycles. State of repair of the units is a big ?
Old 21st June 2010, 15:20   #7
Thanked: 245 Times
Most A.S.S will have the apparatus but I am not sure if they know how to operate it properly and measure the flow and spray etc.
I have myself seen it in Hyundai, they remove the injector, place it in the apparatus, fill the liquid, start it. Do this once more and you are through.
Nobody bothers to put attention to the Spray pattern and/or the flow.
Old 21st June 2010, 15:24   #8
pranavt's Avatar
Thanked: 274 Times
It is the flowtesting part that is important as it could be dangerous for the engine to have a even a single cylinder running leaner than usual and it wouldn't show up nicely on the wideband. Will try and check out a few service centres around Mumbai. Might as well just get them flowtested in the US before they leave for Indian shores. Witchhunter in the US does it for 19USD per injector (cleaning & flowtesting) which is reasonable for the amount of attention they give to them (http://www.witchhunter.com/process2.php4).
Old 21st June 2010, 15:26   #9
pramodkumar's Avatar
Thanked: 947 Times
I have not found a single mitsu A S S have an injecter cleaning machine, of late my cars pull is not linear and usually during cold starts the car sputters, i suspect the injectors to be the culprit but, The A S S i give my car to has no idea how to clean them. I guess some DIY steps posted here might help. Some one please do the needful.
Pramod
Old 21st June 2010, 15:34   #10
pranavt's Avatar
Thanked: 274 Times
Cleaning injectors is one of the things I wouldn't want to do myself, even after having done extensive mods around and inside the engine myself without anyone's help. The usual DIY steps are useless beyond a certain point and you can never really check for linear/equal flow between injectors without a proper flowtesting machine. Inequal flow between injectors causes loss of power and can cause bigger problems if any of the injectors are not flowing properly.
Old 21st June 2010, 15:50   #11
Thanked: 947 Times
got your point, but i remember some one doing it DIY on his versa, thought it would be easy, was not ablt to find the link to that thread.
Pramod
Old 21st June 2010, 17:32   #12
Thanked: 245 Times
The only DIY you can do is add the additive to your tank.
Old 22nd June 2010, 10:20   #13
Thanked: 947 Times
Done that already, used system G for a very long time
Pramod
Renault Duster 110 PS - Fuel Injector Issue suchit23 Technical Stuff 47 18th June 2018 13:43
My Fuel injector cleaning with carbon clean enigmatictech Technical Stuff 17 15th May 2014 20:36
