Old 22nd June 2010, 17:28   #1
Thanked: 825 Times
Default SAE 50 grade oil for Yezdi & Land Rover
Hi all , I am looking for sae 50 or eqi. oil for my Yezdi & Land Rover (series)
Can anyone help ?
Sudarshan is offline   Reply With Quote
Old 22nd June 2010, 22:26   #2
sgiitk's Avatar
Thanked: 3,884 Times
You should be Ok with 20W50, only it is thinner when cold.
sgiitk is online now   Reply With Quote
Old 23rd June 2010, 08:48   #3
Thanked: 825 Times
Respected Sir, I have tried but doesnt work properly , thease old machines are recomended to run on sae 50 ( specially Yezdi/jawa ), I am using Yezdi form 1985 , 5th dec to be precise & used it for a lakh of km. ( not much for those bikes ) it is still on the original clutch plates. It ran very smoothly on Castrol GP 50, since then no oil has matched that performance.
My observations are
1) Yezdi/jawa are not comfertable on any 2T oils ( overheat, rattle )
2) new type of multigrades do not get mixed up with petrol properly.
3) as far as the Land Rover is conserned I have observed following
a) I am using No.40 monograde ,with some kind of oil saver kind of dose
( ocassionaly)
b) Multigrades dont work properly (rattle ,noise , overheat )
4) In Yezdi if a 20/50 is used , clutch & gearchange are not comfortable.
So I am using 70% of normal oil + 30% of 90 EP oil, so far it is working
properly,( for about 20,000 km )
Now I am thinking of attachment like oil pump/ external feed for Yezdi engine ( as mixing of 20/50 with petrol is not working properly)
Thanks for reply
Yours Sudarshan Vaidya
Old 23rd June 2010, 09:26   #4
Thanked: 49 Times
Motul and Castrol have SAE 50 oils available in the UK for classic cars/motorcycles. Sourcing the oil from there should be possible but the costs will probably be prohibitive.
IIRC some marine engines also need SAE 50 grade oil - do check with people familiar with those.
CrackedHead is offline   Reply With Quote
Old 23rd June 2010, 12:11   #5
sgiitk's Avatar
@Sudarshan: I am surprised by your statement, but I guess the engine is a 2-stroker. Then a multigrade WILL not work. Yes SAE90 is what your EP oil is, can be mixed with SAE40 to jack up the viscosity.
Old 23rd June 2010, 17:36   #6
Thanked: 825 Times
Sir, will you please clearify which 'statement ' surprised you ? (I am confused)
More clarifications
1) I am mixing the said sae 40 with the sae 90 , for the gearbox of the Yezdi/jawa, ( not for the engine ) . The manufacturer has recomended sae 50 for the gearbox as well as engine !
2) the Yezdi/ jawa I have Are 2 stroke machines, ( Yezdi is 85 production & the Jawa is a 50 production bike )
Thanks for your reply , Sudarshan.
Old 29th June 2010, 08:45   #7
Thanked: 825 Times
Respected Gurus, and all,
Still no oil, for me ?
Anyone who knows better in this Please help.
Old 24th June 2011, 18:45   #8
Red Liner's Avatar
Thanked: 1,475 Times
Default Re: SAE 50 grade oil for Yezdi & Land Rover
Sudarshan,
this is what we need (I have a jawa twin).
Motul Classic Oil SAE 50 - Oils and Fluids Car Preperation rallying parts for rally cars
Specially formulated all engines of collector cars built before 1950. Suitable for gasoline or Diesel 4 stroke engines. Also suitable for collector bike engines.
PERFORMANCE MOTUL CLASSIC MOTOR OIL is an high performance oil specially designed for old technology engines.
High lubricating power which reduces internal frictions
High film strength available, even in severe conditions
Very low detergency, does not attack seals (TBN : 1.4). Totally inert towards seals used in the past.
SAE 50 viscosity grade adapted to vintage cars or bikes.
Now where in India/Bangalore can we get our hands on this?
Red Liner is online now   (1) Thanks Reply With Quote
The Oil Grade Thread (viscosity etc.) devarshi84 Technical Stuff 7 23rd November 2015 11:27
Synthetic Oil Grade for Palio viana Technical Stuff 4 8th July 2009 09:40
What grade engine oil?? jigarmuni Technical Stuff 45 24th September 2008 09:36
