Old 19th November 2012, 10:06   #151
Thanked: 110 Times
Default Re: Fiat Palio 1.6 GTX issues
Abhijeet: How is your car running? Do you still have shaky rpm.
Vijay
vijaycool is offline   Reply With Quote
Old 21st November 2012, 11:36   #152
Vijay
Hi. The car still has the shaky rpm plus I also need a complete wiring harness for it now. Bought a second car which is running fine so havent had time for the palio, rats ate away HT cables etc, got a cheap fix done and started. Gonna clean the throttle body one last time if it doesnt work then will be needing a new one along with the cables. Gosh Ive spent quite a bit to keep her running. Will hopefully do more to get her in perfect shape as and when time permits. Its my first car
abhijeetveer is offline   Reply With Quote
Old 21st November 2012, 16:42   #153
Thanked: 110 Times
Cause for shaky rpm.
1. weak/leaky vacuum hose
2. Failing ign coil
3. Incorrect timing
4. Weak crank position sensor.
If the engine missing pull between 1200~2500 rpm then definitely O2 sensor.
I have shaky rpm in my GTX and later I found air is leaking from the throttle body IAC valve. Since its a press fit one some how it developed leak on the sides. I sealed with araldite and now the rpm is rock steady.
Also test the idle by disconnecting O2 sensor socket. If the idle stabilizes after dismantling needs sensor replacement.
Weal crank sensor is known for shaky rpm. Make sure the sensor and phonic wheel gap is atleast 0.8mm
Replace sparkplugs with NGK BKR5E and the plug gap is 0.8mm.
vijaycool is offline   (1) Thanks Reply With Quote
Old 22nd November 2012, 17:34   #154
R2D2's Avatar
Thanked: 2,039 Times
Hi Guys,
Need some help.
My Dad's 2002 Palio 1.6 GTX is in need of a service/check-up.
I am not too keen on the garage that he used to take it to (Car O Care @ Wanowrie Pune) and was hoping to get some pointers from TBHPians on a good i.e. knowledgeable and honest Fiat technician in Pune. I am hesitant to give it to a Fiat ASC for obvious reasons.
Old 22nd November 2012, 18:03   #155
Thanked: 95 Times
I have heard that a chap called Vijay who is ex BU Bhandari is quite good and people from even as far as Bangalore have driven to his garage to get their Palios fixed. You could request the info from Palio Users Group. Should be pretty easy to get since Pune Fiaters would invariably have his contact details.
I may have got the name mixed up. I recently met up a couple of Pune Fiaters who were raving about this chap. A couple from the Bangalore group also acknoledged his expertise. Let me do some digging up and see if I can get contact details
zoombiee is offline   (1) Thanks Reply With Quote
Old 25th November 2012, 20:54   #156
R2D2's Avatar
Bro, any luck? I'd appreciate the name and contact details. If folks come all they way from BLR to this person's garage he must be quite an expert.
Old 26th November 2012, 08:38   #157
Thanked: 95 Times
Hey sorry man. Was busy the last few days. Give me a couple of days time.
zoombiee is offline   Reply With Quote
Old 26th November 2012, 09:39   #158
comfortablynumb's Avatar
Thanked: 1,026 Times
Did you mean Ravi, rather than Vijay?
http://autos.dir.groups.yahoo.com/gr.../message/80446
Cheers,
Vikram
comfortablynumb is offline   (1) Thanks Reply With Quote
Old 28th November 2012, 09:02   #159
Thanked: 95 Times
Cheers,
Vikram
Yes you are right. I was able to contact my friend and the name is Ravi Gaikwad. I think contact details are on the PUG thread.
Old 2nd December 2012, 19:36   #160
Hi Guys,
Need some help.
Hey. I think I have seen your GTX at car o care if its silver/grey. I had gone there but didnt find it so good.
Vijay,
I will try out what you said. In the mean time I am thinking of selling my sonata and replacing it with a clean octavia RS. What should the right price for a 2005 well maintained 33k kms with service history octavia rs be? And what should I look out for. I have already gone through amjats threads and know the issues.
Old 2nd December 2012, 19:44   #161
R2D2's Avatar
Dad's car is white. My beloved father passed away at the end of August. :-( I will keep this car in his memory though one of his dear friends offered to buy it. I declined. It needs a bit of work including body panel suspension, gearbox & steering. Will do it up as and when budget and time permit. I remember this car when it was brand new, it was such a joy to drive.
Old 2nd December 2012, 19:52   #162
Sorry to hear about your father. I too am keeping the car because of the sentimental value. Mine needs a lot of electrical work and maybe a new throttle body. We should catch up next time I am in pune. Maybe my car can use your cars throttle body to see if mine is at fault. Mechanics gave me this easier and quicker solution and I know no other GTX owners.
Old 2nd December 2012, 19:57   #163
R2D2's Avatar
Sure mate...send me a PM a day before you come over to Pune.
Old 23rd November 2014, 00:34   #164
swiftnfurious's Avatar
Thanked: 6,581 Times
Hey, Could anyone let me know of a credible mechanic for the Palio 1.6 GTX in Mumbai?
swiftnfurious is offline   Reply With Quote
Old 25th November 2014, 00:53   #165
Thanked: 70 Times
Hi
There is one at panvel. Some ex-fiat technician
RS motors at charcop. Many guys are ex-amuroop auto guys
And mr sunil shanbaug, select auto dadar has worked on petra 1.6
rikhav is offline   (1) Thanks Reply With Quote
Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences moralfibre The Indian Car Scene 140 21st May 2014 17:21
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
The GTX arriveth. Palio 1.6 GTX thedragula Long-Term Ownership Reviews 36 12th June 2011 12:40
2002 palio 1.6 GTX (or) 2006 Baleno (or) New palio stile 1.6 sports (or) Ford fusion Mr_Bean Hatchbacks 31 16th December 2010 17:12
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
