Old 6th April 2016, 12:31   #181
Thanked: 512 Times
Default Re: Fiat Palio 1.6 GTX issues
Facing an issue in my 2003 GTX 1.6 which has run 87000 KMS.
Did a long drive from Bangalore to Madikeri and back over the weekend. This was the first long drive after I started restoring the car and it drove beautifully without any major issues except for couples of things.
It returned me a mileage of 14.5 overall with 100% AC and I was really happy with it. Also I seldom went above 90 KMPH
Issue - Pick is quite low in 1st and 2nd Gear and also the engine makes kind of grinding noise as if its getting strained. The RPM keeps raising, but car is not moving anywhere in the 1st and 2nd gear. Other smaller cars with 4 on-board managed to out run me in 1st and 2nd Gear which was never the case before. 3rd gear pick up is good though.
Cant make out if this is due to flywheel/clutch issue. I had faced the fly wheel around 10K KMS back as there was major shudder while releasing the clutch and also flywheel is super expensive at 16K.
Also I have shifted to Mobil 1 mineral oil from Shell H7 Semi Synthetic this time on mechanics recommendation
Otherwise, there was no engine work done at all during painting/restoration.
chandrda is offline   Reply With Quote
Old 6th April 2016, 12:52   #182
h14
h14's Avatar
Thanked: 1,721 Times
RPM raising and car not moving, I can attribute only to the clutch. How old is your clutch? Any abnormalities you felt while shifting gears? Especially 1 or reverse?
h14 is offline   Reply With Quote
Old 6th April 2016, 13:50   #183
Thanked: 512 Times
Clutch was changed at 75000 KMS and when the shuddering dint stop, I got the Flywheel faced at 77000 KMS. The shuddering had stopped and slowly creeping in now.
There was no issue at all, but after I got the car repainted for which it was in the garage close to 40 days the pick up is down and there is grinding noise.
There is slight shudder in the 1st and reverse which is persisting from last 20 KMS
Old 8th April 2016, 08:27   #184
machinehead's Avatar
Thanked: 26 Times
Very similar to the way my Palio 1.6 clutch packed up. This was after 40k kilometres. Clutch replacement and fitting is a highly skilled job and has to be done properly. Check your fluid levels, in this case the brake fluid it operates the clutch system. The clutch plates along with the pressure plates and the flywheel need to be mounted to exact specifications. There could be an issue there or alternately I would suggest you get your master and slave cylinder checked or changed as it could be that adequate pressure is not being applied on the clutch system because they are faulty. Hence the shudder.
machinehead is offline   Reply With Quote
Old 11th April 2016, 09:45   #185
Thanked: 512 Times
My Slave cylinder started leaking around 2000 KMS ago and I changed it with TVS Girling, but dint change the Master Cylinder. Even before I changed the slave cylinder, the problem had started, but has only aggravated now.
Brake fluid is upto the mark, but I have the tutela DOT4 with me and going to bleed the entire brake/clutch fluid tomorrow and replacing it with Tutela DOT4.
Also I will get the Master cylinder, slave cylinder, flywheel and pressure plates checked.
Meanwhile got a photo courtesy of my son.
chandrda is offline   (1) Thanks Reply With Quote
Old 15th April 2016, 11:57   #186
bottle's Avatar
Thanked: 138 Times
Please do keep us updated , I too am facing shuddering while releasing the clutch pedal in 1st and 2nd gear and would like to know what cures it for you
bottle is offline   Reply With Quote
Old 18th April 2016, 09:33   #187
Thanked: 512 Times
I went to the garage last week to get every thing checked as above, but there was no power so waited for some time and had to return.
Meanwhile did another round trip of Bangalore - Madikeri (520 KMS) in the weekend. This time the car returned a mileage of 13.3 KMPL. But the engine sound and pick was awful.
I can't leave with this engine sound, shudder and pickup. Will go again this weekend and get everything removed and checked. Will keep all updated.
Old 24th December 2016, 02:36   #188
Thanked: 105 Times
Any updates? @chandrda
Micki9559 is offline   Reply With Quote
Old 26th December 2016, 10:44   #189
Thanked: 512 Times
Things have gone only downhill from April. I Changed the Flywheel and Clutch Kit somewhere in July. Where thing was fine for couple of weeks and then problems started again.
1. Shudder continues and doesn't go away at all.
2. Now there is huge vibration at particular speed, RPM and load combination
3. Pick up is gradually decreasing and mileage in city has dropped to 8
4. Engine grinding noise has only increased and feels like a flour machine.
Work is keeping me away from Bangalore and I am planning to back in February. I will check and take a call at that time.
Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences moralfibre The Indian Car Scene 140 21st May 2014 17:21
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
The GTX arriveth. Palio 1.6 GTX thedragula Long-Term Ownership Reviews 36 12th June 2011 12:40
2002 palio 1.6 GTX (or) 2006 Baleno (or) New palio stile 1.6 sports (or) Ford fusion Mr_Bean Hatchbacks 31 16th December 2010 17:12
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
