Old 20th September 2016, 23:44   #16
mayankk's Avatar
Thanked: 3,489 Times
Originally Posted by rrsteer View Post
I used the term off-road liberally. What would be a term for just off the metal road? -snip-
Jeeps are not an option, as they would be very uncomfortable for others.
That's way too liberal, no?
The kind of "off roading " that implies, I've done in my fiesta, and a friend's city enroute to kufri, and in lansdowne. As long as its a track, cars are fine.
Caught TG's Patagonia special?
Do consider the weight and the length of your innova, though. Get some chunky tyres and underbody protection, to start with.
mayankk is online now   Reply With Quote
Old 21st September 2016, 07:32   #17
Sheel's Avatar
Thanked: 4,828 Times
Default Re: How to make Innova more capable off road?
Ideally, in your shoes and having got a Fortuner, I would have upgraded the suspension and got an aftermarket suspension which was less wallowy than stock, Michelin AT tires would have replaced the stock ones and that would have been more than enough.
The innova is a rear wheel drive, so, you can use the handbrake to get out in sticky slushy situations.
Could you please explain as to how to go about this? I am sometimes forced to drive a 2WD trucks or vans, will help here
In the last week of July had to take a detour because of a road-block. This detour went through tarred roads but tractors and trucks had put a good amount of mud on these roads and it was all slush. Tar below and thick slush on top of it. A UP-65 [Varanasi] registered Innova simply went and banged itself into a parked truck when it hit its brakes, there was no traction to speak of. What could one do here?
Originally Posted by mijnoirhammer67 View Post
The X5 with x drive and Q7 with quattro, they are beats which can tackle just about anything.
Q7, Q7 as a beast? Source
I am sure the X5 or most soft roaders will meet the same fate. These Germans don't make their SUV's reliable enough and nor can they properly off-road.
Sheel is offline   (4) Thanks Reply With Quote
Old 21st September 2016, 21:17   #18
dhanushs's Avatar
Thanked: 4,055 Times
Well, in case of a vehicle getting stuck with an open differential, ie one wheel in slush, and the other wheel which has traction getting zero torque, you just need to pull the hand brakes not really tight, but, to some extent, and drive.
Instead of zero torque which was delivered to the wheel with traction, pulling up hand brakes will deliver atleast torque which is necessary to overcome the brakes, and hence the vehicle moves.
dhanushs is offline   (3) Thanks Reply With Quote
How to make Innova more capable off road? rrsteer Technical Stuff 12 21st September 2016 07:32
Government will make safety norms more stringent, but no plans to make airbags mandatory Tushar The Indian Car Scene 39 9th September 2016 14:27
Thinking Aloud : 4wd Offroad capable Jungle Safari vehicle.....the build is on abheekg 4x4 Vehicles 135 28th November 2014 19:18
Mm550 The Capable Offroad/onroad Vehicle V-16 4x4 Vehicles 181 29th August 2011 09:52
