Old 24th June 2010, 08:28   #1
ghodlur's Avatar
Thanked: 2,438 Times
Default Noise from Brakes in my Ford Fiesta
I have experiencing noise from the brakes in my Ford Fiesta esp when the brakes are gradually released. Dont know if its from the front and rear brakes. I feel its from the front since they are disc brakes and maybe the brakes are not getting released smoothly. I had mentioned this to the dealer during the regular service and was told that it was common. But these days the growling noise which I hear when I release the brake pedal has increased. Is it because of the wet monsoon conditions that the brakes are sticking more or is ti due to rust as seen in the attachment.
What could be the reason for the same, BHPians advise.
ghodlur is offline   Reply With Quote
Old 25th June 2010, 10:02   #2
arishi1's Avatar
Thanked: 12 Times
Did you try bleeding the brakes, Just a wild guess that if there is small air buble the brakes will take time to release.
arishi1 is online now   Reply With Quote
Old 25th June 2010, 10:27   #3
nairrk's Avatar
Thanked: 37 Times
Infractions: 0/1 (5)
Did you drive through water, upto or above the tyre centre line?
Then there are chances to get the brake discs WET which may result in
reducing braking efficiency and some noises also. Or the brake may not be getting released due to rust formation (that too might have happened due to tyre immersed in the water for some time)?
nairrk is offline   Reply With Quote
Old 25th June 2010, 10:27   #4
ghodlur's Avatar
Smile
Can you let me know how to do that, can it be done by me or should i take it to the service workshop.
Old 25th June 2010, 10:45   #5
Thanked: 435 Times
My colleague had a similar issue, and the Ford Authorized in Trivandrum asked him to get the discs grinded/polished (Not the brake pads, only the discs).
He is yet to get this done because he doubts whether the dealer is trying to fleece him (He was quoted Rs 4000 for polishing four discs).
jinojohnt is offline   Reply With Quote
Old 26th June 2010, 03:30   #6
dezmo007's Avatar
I think this is quite normal in monsoon. It normally happens if the tires and breaks are wet.
dezmo007 is offline   Reply With Quote
Old 26th June 2010, 04:37   #7
Question ABS?? Dirt ??
You said the brakes were "growling"? Are you sure you didn't mean squealing? - A high-pitched sound? If they were squealing, there are several possible reasons - dirt/rust, worn pads, or even as someone else mentioned a slightly bent or scarred disc - all of which require a trained mechanic.
If on the other hand you are referring to a low-pitched sound, I can only think of ABS as the culprit, but does your car have that??
sunnysideup is offline   Reply With Quote
Old 28th June 2010, 12:42   #8
ghodlur's Avatar
Angry
I would not know whether the "growl" I hear is the same "Squeal" you mentioned but defintely I hear the noise and its from the brakes allright. I think as dezmo007 mentioned maybe its because of monsoon and wet tyres/brakes. I need to show it to the service guys.
Old 29th June 2010, 00:35   #9
Smile
Well good luck and do let me know how it turns out; I have a similar 'noise' problem from my Civic and am in the process of earning a PhD in trying to identify it's cause!
Old 29th June 2010, 10:25   #10
yogi1771's Avatar
Hi ghodlur nothing to worry about it is due to the brakes that get rusted during monsoon season,for that matter if you park the car for a few days the brakes get jammed(handbrakes applied) and get released only after a bit off dab on the accelerator.
yogi1771 is offline   Reply With Quote
Old 29th June 2010, 10:35   #11
pramodkumar's Avatar
Thanked: 947 Times
@Ghodlur, usually if this sound comes while appling the breaks then the issue is you pads are wornout and need replacement, there is something called the wear indecator and that rubs against the disk to make that sound, For this you dont have to belad the breaks as that is done for a tottally different thing, even after realising the breaks the break pad still remains in contact(this is normal) with the disk, have your pads checked if you see any wear have them replaced or get them cleaned using sandpaper.
Pramod
Old 30th June 2010, 09:26   #12
ghodlur's Avatar
Smile
@Ghodlur, usually if this sound comes while appling the breaks Pramod
@Pramod
I hear the noise only when I release the brakes and not when I apply it. A typical case would be when I remove the car from parking for office I hear this noise, when I release the brakes in a signal, I hear it. During running if I apply the brakes I dont hear it.
Will be taking the vehicle to service guys this weekend. Hope fully it should be resolved.
Old 1st July 2010, 09:43   #13
Thanked: 103,644 Times
Handbrake cable / rear drum brake getting jammed. Simple greasing / cleaning job required.
OR
If you park in the direction of the rain, water in the brakes. Typical problem that resolves by itself (after couple of kms of driving).
Old 27th May 2013, 16:41   #14
Prodigy07's Avatar
Thanked: 329 Times
Default Re: Noise from Brakes in my Ford Fiesta
I was facing the same issue in my Fiesta as Ghodlur had mentioned. I was never satisfied with the quality of service at MPL Ford Chennai. This brake 'squeal' problem was reported to FASS couple of times but not was never resolved. Their reply to my problem was 'Aftermarket alloy wheels and tyres sir, that could be the issue!'. After my team-bhp membership was approved, I stumbled upon this thread So, this time as per jinojohnt I avoided FASS and took my Fiesta to Bosch Service Centre Ramapuram Chennai. The service centre folks took a quick test drive and found the culprit to be the poor quality Ford Brake pads. These brake pads had damaged the discs too. So, the Bosch SA advised that the brake pads had to be replaced and the disks had to be skimmed/polished. The estimated time for this work would be 2 hrs. I asked them to go ahead with the job. The end result was The price break-up 1148/- for Brake pads, 500/ for Disk Skimming and 400/ for labour. The brakes are top notch now and there is absolutely no sound from the front disks.
Prodigy07 is offline   Reply With Quote
Old 27th May 2013, 21:34   #15
freshseasons's Avatar
The recent spares from Fiesta has been pretty questionable not that its evident all over but some things like disc brake pads have had their share of issues. The thing is the new pads are pretty rough made to last long and they grind against disk making the noise.
Pretty confused as advising aftermarket pads is so subjective to the quality almost having huge peril and FASS providing with sub -standard pads .
freshseasons is offline   Reply With Quote
Noise from the Brakes kaushik_s Technical Stuff 71 3rd May 2017 15:13
Grinding noise coming from the front brakes of Swift Vxi when rolling back vivekchugh Technical Stuff 10 9th October 2015 21:06
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
Ford Fiesta - A/C Noise funda2max Technical Stuff 15 21st April 2009 10:00
