Old 3rd May 2011, 18:22   #46
HappyRoadie's Avatar
Thanked: 186 Times
Default Re: Tata Sumo Grande Problems
Thanks wildchild for the information. I am not worried about that rubber thing. I am only worried about the discs problem and leaf springs getting misaligned. I dont carry too much load in my car but still this happened. Their was also some noise coming when turning the steering. It was also sorted out.
When my car was new the pressure pipe bursted. Since my purchase I am facing minor or major problem.
HappyRoadie is offline   Reply With Quote
Old 4th May 2011, 10:19   #47
wild child's Avatar
Thanked: 141 Times
you are most welcome roadie
anyways, leaf spring misalignment can be caused because of an improper reversing of the vehicle. I'll tell you how. The grande is quite a high vehicle ( high ground clearance). The height of the shackle from the ground is almost same as the height of some road pavements and also steps in some houses / appartments. So when the vehicle is backing up, some drivers may not be able to see the steps which is behind the vehicle. They might reverse the vehicle too much such that the shackle goes and bangs against the steps thereby misaligning the leaf spring. this could be a probable cause. I had the same complaint in my old sumo.
What is the disc problem which you are taling about ?
wild child is offline   Reply With Quote
Old 4th May 2011, 18:45   #48
Thanked: 186 Times
The discs problem I am facing is that in every 6 months the discs get damaged and are changed. Again they get damaged and again they are changed. This is happening since my purchase. I am really tired of this car and planning to sell it in 2-3months. Hope to hear your advise soon.
Old 5th May 2011, 10:05   #49
wild child's Avatar
Thanked: 141 Times
what do you mean damaged?
Old 5th May 2011, 11:13   #50
Thanked: 186 Times
Damaged means that they get bent. I cannot exactly say because my driver used to take the car. The manager there promised me that he will change the car but before that asked for last warning. But the problem is still not solved.
Old 5th May 2011, 16:01   #51
wild child's Avatar
Thanked: 141 Times
discs are designed to only rotate about its own axis and they do not have any other relational motion between other neighbouring components. they get bent only if the vehicle meets with an accident or the vehicle falls down from the jack with the tyre removed.
anyways, if the dealer had offered you a free swapping of the vehicle, then you could have gone for it instead of just giving the dealer a " last warning" as you said?
Old 13th May 2011, 18:34   #52
Thanked: 186 Times
Today I had taken my car to Motorsales to get the car checked as we are going for a trip on 21st. Also the car was jerking while breaking. The conversation to the person there is as follows.
Mechanic - Sir what is the problem
Me- Car jerks on breaking.
Official- Sir it will not go.
Me- Steering makes noise when turning it.
Official - Sir this also will be present.
Me- Jerking is present. He replied sir these problems cannot be cured.
I asked the reason and hesaid that the car has manufacturing fauly and the problems will never be sorted. He said that due to this Grande has been stopped and was not a success.
But the discs were not damaged and I drove back home without having need to change the discs.
Old 13th May 2011, 18:47   #53
mercedised's Avatar
Thanked: 177 Times
@Happyroadie:
I think that your brakes are getting stuck? This problem is mainly due to faulty Brake Booster. Tell them to check all the vaccum lines and especially, Brake booster + brake master cylinder.
mercedised is online now   Reply With Quote
Old 13th May 2011, 20:33   #54
Thanked: 186 Times
@mercedised I think this is not the reason because they have changed the whole assembly of my car.
Old 14th May 2011, 11:39   #55
Thanked: 9 Times
Please help and advise me whether I should proceed with this step or not. Your suggestions will be valuable for me in making the decision
Write mails to big shots in Tata, bring their notice to this thread and even then if nothing happens, think of proceeding with a legal course. You can also spread the voice through other online forums also e.g. facebook
pratikraveesh is offline   Reply With Quote
Old 14th May 2011, 13:07   #56
Thanked: 186 Times
I have sent mails to many people but no one replies back. I have even contacted Head of Customer Care but their was no response from his end also. I would request anyone who has number of any high authority in TATA to please provide me with the number so that I can talk further rather than dealers.
Tata Sumo Gold - Refreshed Sumo! safari_lover The Indian Car Scene 466 5th June 2017 14:00
Tata Safari or Tata Sumo Grande orrr... what?? EDIT: Finally it is a Mahindra Scorpio gshanky SUVs, MUVs & 4x4s 90 29th January 2010 20:39
SCOOP! New Tata Sumo Picture. EDIT : Now launched as Sumo Grande MillionSwords The Indian Car Scene 217 26th October 2009 20:16
Tata Sumo Victa GX IDI Turbo or Sumo Grande GX drmessiah SUVs, MUVs & 4x4s 11 20th April 2009 18:16
Tata launches New Indica, Indigo CS, Indica V2 DICOR, Sumo Grande, Xenon. Details.... ashutoshb The Indian Car Scene 102 19th December 2008 22:53
