Old 24th June 2010, 20:34   #1
Frank Zappa's Avatar
Thanked: 12 Times
Default SKODA VRS lowering springs any problems
Hi Guys,
Would appreciate some feed back from anyone who has lowered a Skoda VRS using UK spec springs. Does the car end up scrapping the bottom at all the speed breakers as that could be a very serious issue on Mumbai roads. Just want to know from somebody who has already done it. I have Bilsteins with OE springs on my VRS presently. I am being told that the car will get lowered by about 15mm.
Any advice and feedback from users will be much appreciated.
tks
Frank Zappa is offline   Reply With Quote
Old 25th June 2010, 16:32   #2
msaudf's Avatar
Thanked: 146 Times
To have your doubt cleared you'll have to simply calculate the effective ground clearance after the lowering.I'm guessing the skoda octavia with 4 people in it will go down about 20mm in the rear and about 10mm in the front. with your new springs being 15mm lower than the Indian spec ones, its easy to predict that your car will scrape speed bumps.
but that can be avoided if you also fit stiffer dampers with your lower springs. i think they'll help..
cheers
Saud
msaudf is offline   Reply With Quote
H&R Lowering springs from Germany for my Maruti AStar! Sankar Modifications & Accessories 34 7th August 2014 11:08
Skoda Octavia VRS - H&R Springs Modification Query HAFI Modifications & Accessories 2 2nd November 2011 07:16
H&R Springs On Stock Shocks For A Skoda RS HAFI Modifications & Accessories 15 7th May 2010 05:54
Lowering Springs for Baleno crazydiablo Modifications & Accessories 17 9th July 2009 08:31
Lowering suspension(ground clearance or ride height) for the SX4 dharmana Modifications & Accessories 27 29th April 2008 22:34
