Old 11th July 2010, 15:28   #16
mithun's Avatar
Thanked: 59 Times
5) Damage to the Top gear in the gearbox.
OK, I admit that the engine would rev higher because of a faulty clutch plate(at the highest gear) when compared to good clutch plates.
But, how will that cause damage to the top gear ?
Old 11th July 2010, 16:51   #17
condor's Avatar
Thanked: 4,907 Times
+1. Why would the top gear suffer ?
GTO : Simplest way to gauge is the clutch slipping. That is, when the rpm needle rises disproportionately higher than the speedometer.
GTO, one question :
My tacho & speedo readings are as before. But I feel the pickup has become a little soft. Also, the Sumo is jerky when I go up a ramp / incline, in first gear with zero acclerator. Why should this be ? This has started about 500 km back. Till recently, I used to go up ramps happily (like when coming out of basement parkings).
IND-style Number Plates : Movell Captain Slow Other Cities 72 21st July 2018 14:44
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Clutch replaced but still having vibration problem prasannapatil Technical Stuff 13 12th May 2009 11:27
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
